Rear Diff Swap (Torsen)
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
messing with a pinion flange also has to do with the crush washer to unless you have torque specs for just the flange without the crush washer installation for the pinion gear you're rolling the dice on a critical component. i wouldn't. whole pumpkin is the way to go imo.
Normally you would be correct, but in this case…. See the Ford supplied instructions posted above.
Oakley
Lee
2022 Mustang
looks like i'm just correct cause they give you specs to do that lol
MrMike
MrMike
US
Definitely still easier to swap the assembly. You have to remove and replace the assembly either way. The pinion does not have to come out if only replacing the carrier(tracklok or torsen).
Ok so everything but the pinion comes out, which is still a bit rough for someone with zero experience. I'll just check every couple days for a low mileage Torsen.
Oakley
Lee
2022 Mustang
They do not give you a spec to do that, but they do tell you how to measure the spec needed to do it.
specifying a procedure for doing a job is giving... specifications... specs....
TeeLew
So Cal
Tim
That's rotational torque, which is the proper method. That number is typically in the range of 20-30 in/lbs
Even lower, like 12-15 in/lbs. Changing the flange is not a big deal other than the big Jesus nut is deform-locked on and takes a bit of time with a punch/chisel to free up. It seems like people just go out of their way to make things a big deal that just are not.
TeeLew
So Cal
Tim
You will need several other tools, including a dial indicator to build it. Just swapping to a torsen with the same ring and pinion isn't a horrible job. Replacing the pinion is where it gets significantly more difficult.
Exactly.
TeeLew
So Cal
Tim
Which is why you do the roll-over torque before you pull the nut. You're not changing crush or anything related to pinion position.
bankyf
2022 GT500 CFTP
The spec in my WSM is 22-34 lb-in which is actually higher than most diffs I’ve done.
TeeLew
So Cal
Tim
That's fair. Mine was a little lower.
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
I got mine from midway mustang out of a 2019 gt auto 355 torsen 27k miles on it for my 2019 gt auto but i have never Heard of anyone say that there been any trouble when changing a differential and have vibration after the installation
MrMike
MrMike
US
Does anyone know the part number for the 18-23 manual driveshaft?
I think it's JR3Z-4R602-Y based on parts sites but I am not 100%.
