R&T stated that Voodoo is close to 600HP instead of 526HP
Twenty4/7
Central Florida
Robert
2021 RR GT500
Depends on your driveline loss factor. For RWD, big tires and a roller dyno? 18% is common. Using that at 470 RWHP you get over 570 crank. Closer to 600 than to 526. I bet the car has a real 550 crank.
been dynoing cars for the last 10 years or so. 18% isnt really the norm for newer cars especially "sporty" ones. i think drivetrains have become more efficient AND sae hp ratings have changed in the last 10 years equalling lower advertised bhp. so being closer on the dyno to advertised bhp makes sense.
shogun32
Northern VA
Typically magazines quote crank horsepower for stock/factory cars since it's what the manufacture is rating it at.
because the factory has an actual engine dyno. They claim crank because they really are measuring crank output. If your dyno measures at the wheel then the only possible assertion they can make is wheel. And that's ignoring all the variables and 'massaging' the operator makes. Any claims made about crank from wheel are pure conjecture and guessing. If the operator is any good the guesses may be pretty accurate but the error bars are still quite large.
Rev Happy
Los Angeles
2020 GT350R, 2023 BMW X3
because the factory has an actual engine dyno. They claim crank because they really are measuring crank output. If your dyno measures at the wheel then the only possible assertion they can make is wheel. And that's ignoring all the variables and 'massaging' the operator makes. Any claims made about crank from wheel are pure conjecture and guessing. If the operator is any good the guesses make be pretty accurate but the error bars are still quite large.
Correct but I thought we were just referring to the R&T article or magazine articles in general when they quote crank HP for stock cars. Either way, not saying you were wrong, just wasn't initially sure what you were directing it at.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Hot Rod tested a stock gen 3 coyote through factory intake, factory headers & cats & calibration and got 495 crank HP.
mavisky
Cumming, GA
Kyle
2018 GT350
Thwy
Was that with all the accessories or without? Most of the testing I see them do is without and that can make a sizable differencd
stanglife
Jeff
1993 Coyote Coupe
Can we start a new rumor? 2019 and 2020s have more horsepower!
shogun32
Northern VA
and they'll keep advancing timing all the way to 110 octane and will literally fly if you put the purple drank (unleaded AVgas) in the tank.
Meatball
CA
17 GT
I think the Gen3 has more power than advertised but not by that much. More like 460 statistical minimum, 470 or so typical. If it really had 495 it would blow away 455hp Camaros, which isn’t the case. Car & Driver uses standardized methods for accel testing and got trap speeds of 115, 114, 114 and 114 for the manual GT they tested 4 times (+ a 115 if you count the Bullitt). They got 116 and 118 IIRC for the 455hp Camaro which weighs under 100lbs less. 470 is about right for the 18+.
You’re confusing engine power with the amazing A10, esp combined with the gen3’s power curve. C&D got a 120mph trap speed with the A10GT the one time they tested it.
LSchicago
Illinois
Lloyd
Thwy
Alternator was on it, but I don't think the AC was on it.
Point45
SoCal
josh
19 gt350, 05 tacoma, 10 Ducati 1098SF
I love it when people talk about hp/tq it's like listening to fishing stories.
Someone on YouTube claimed he went 200mph in his 350.
Simple, this car just feels like a 500hp range car when you drive it. That and the countless dyno pulls. I wish it was a 600hp car but even if it was, it doesn't drive like one.
nastang87xx
Wisconsin
2016 GT350 Track Pack
A stock 526 hp gt-350 can barely beat a 10-speed gt with 66 less hp. 600 no way probably more like 490 crank hp.
Did you come over here to just start an argument? 526 rating is reasonable. And if we all had 10 gears automatic gears to play with we'd be running silly numbers too. Plus beat it in what? Quarter mile? Standing mile? Time Attack?
In the quarter mile, trap speeds for both cars are about the same. In the 350's court, that's pretty good for an engine that has zero nut down low and starting from a stand still and running through 4 incomplete gears. The 10R80 cars run through nearly 6. Shows how healthy the top end of the GT350 is.
nastang87xx
Wisconsin
At one point in development it was significantly higher than 526. Blame packaging, bean counters, and that stupid flywheel.
nastang87xx
Wisconsin
I think MT needs to stop using K&N's dyno too which is routinely generous.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
1st of all this thread isnt off limits to people who don’t own a gt-350, lets get that outta the way. Second of all the primary attributes of a gt-350 is its handling prowess not its so stated 526 crank hp. Not starting any fights, just stating for the power it claims to make it should roast a stock ten speed gt regardless of the fact that its a manual. Maybe the Tremec transmission gears should be more aggressive, Who knows. Ford should have given it more down low. Or maybe a set of 4:10’s would do the trick. The 2 cars are closer then they should be just going on the hp claims, that’s all I’m saying.
john@fatfab
Gold Sponsor
Indianapolis
Shelby Omni
We have tons of baseline dyno runs for 350s and several 10 speed GT cars. I picked a couple of "average" results from both platforms and overlaid them. I did them in both RPM and wheel speed. Again trying to confidently say what actual crank HP from a chassis dyno is useless. Chassis dynos are good for looking at gains from other runs or comparing other cars done on the same dyno.
