R&T stated that Voodoo is close to 600HP instead of 526HP
lenFeb
USofA
Len
2019 Shelby GT350 #K0110
lightrules
West Coast
Yes
i dont believe it. R&T simply asserts it. and that MT dyno is a total anomaly; something isn't right with it. look at pretty much any other baseline dyno of a gt350 it's making anywhere from 445-470 rwhp (variation of 91 or 93 and other factors), which is about right for a 526 crank hp car.
fathouse baselined a 2020 gt350 and it was 469 rwhp. woman driven put down 462 rwhp. PBD did a 2019 and it showed between 457 - 463 rwhp and they said that is what they consistently find.
so 600 crank? no.
key01
Chicagoland
2017 GT350 now gone to a great home.
Wow, now that is weird. What hearsay source did they pick that up from?
JR369
2022 GT500 Iconic
so 600 crank? no.
100% agree but maybe we can get @Trevor@FatFab to come in and discuss their stock dyno results from the many 350's they've had.
mavisky
Cumming, GA
Kyle
2018 GT350
Every single dyno I've seen of a stock GT350 shows them to be in the 455-470 range depending on weather conditions and dyno type. Anything outside of that would be chalked up to dyno operator error. Time and time again these major magazines have taken vehicles to these dyno sessions and received non-standard numbers. Not sure who they're using out there in California, but they seem to be really struggling with operating their dyno's well.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Hogwash.
The only way I could see that would be a gross crank rating without front engine dress/accessories. Still a stretch.
john@fatfab
Gold Sponsor
Indianapolis
Shelby Omni
This is about the range we see on all of the baseline dyno runs on the GT350s. I will have to look back at some of the runs but I think we have seen a low of maybe 447-448 and a high of around 473-475 from what I recall. Most are somewhere around 460. I think it has more to do with the quality of the fuel they have been ran on prior to and during the dyno pulls.
ATB042
MA
Andy
2000 Honda S2000, GT350R KR717
Depends on your driveline loss factor. For RWD, big tires and a roller dyno? 18% is common. Using that at 470 RWHP you get over 570 crank. Closer to 600 than to 526. I bet the car has a real 550 crank.
shogun32
Northern VA
why would anyone quote crank if it's not measured at the crank? the numbers are pure conjecture. only wheel is useful and valid.
ATB042
MA
Andy
I am not sure what you are getting at. The factory publishes a crank number and peoples dyno numbers seem to support that it's a little conservative.
Dyno numbers are just as dangerous to use. What type of dyno? Roller? Hub? What correction factors are being used? Smoothing?
The only real thing a dyno is useful for is tuning but when you have a pile of data showing around 470whp, you can logically make an assertion that 526hp was a conservative factory rating. Not that it means anything.
Rev Happy
Los Angeles
2020 GT350R, 2023 BMW X3
I'm also not sure what you're getting at. Typically magazines quote crank horsepower for stock/factory cars since it's what the manufacture is rating it at.
john@fatfab
Gold Sponsor
Indianapolis
Shelby Omni
I agree. Comparing numbers across many different brand of dynos is useless. Every build we do starts with a baseline number so we know what each car makes on our dyno before and after. The gains you see are the only the only numbers that I would trust. We also went with dyno jet as you can't fudge the drum weights to get different results.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
A stock 526 hp gt-350 can barely beat a 10-speed gt with 66 less hp. 600 no way probably more like 490 crank hp.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Drivetrain losses on the S550 are about 13%in real life.
john@fatfab
Gold Sponsor
Indianapolis
Shelby Omni
Just for apples to apples on our dyno, baseline numbers for 2018+ 10 speed cars are around 405-420. So on average about 40-50 hp less than the GT350s
