Quiet Mode 24/7?
MSheets
Lenoir,NC
Michael
2022 Mustang GT Premium, 2016 F150 XLT Sport, 2022 Edge SEL
It won't do anything. I ran a Borla tuneable catback exhaust on my '92 Camaro. It had a plate that was fully closed to completely open on the bypass side. You had to manually chage the plate under the car.
TonyNJ
Northern NJ
www.instagram.com
Tony
The Mustang AE set up is unfortunately a little more fragile. Springs in plastic actuators. 🤷‍♂️
Xpdwheel
Sumter County Florida
2004 Silverado 2005 FLHPD 1977 R100/7
Do not go WOT in quiet mode. Problems.
Hey Tony,
Have you had an issue? I’ve been known to get on it in QM. Curious what might have happened to you. Thanks ever
Never mind I just got the vid.👍🏻
D Bergstrom
North Las Vegas, NV
Doug
2020 Mustang GT
I'm referring to the OEM set up. Not that familiar with the borla style. The OEM doesn't open via computer at WOT. It opens via selection on toggle or steeringwheel. Maybe it's forced open a bit from added exhaust pressure, but that puts stress on the actuators, increases back pressure, and builds up heat. I've had actuators go bad, and developed rattles in the butterfly valves. I believe it's from valves not being fully opened when driving hard.
Edit: I'm not suggesting you're going to blow your engine. But it's certainly putting stress on the AE actuators and valves.
Did you watch the video at all? The valves they are showing are the stock valves. The valves do open in quiet mode at high RPM. Not all the way, but they do crack open releasing pressure. Watching the video again, they don't really seem to open much more in normal mode at wide open. Having an aftermarket exhaust has nothing to do with it, your actuators/programing is still Ford, works exactly the same regardless of exhaust system choice. The valves themselves looked exactly the same on my oem mufflers as they did on my Borla mufflers. You mentioned you have had problems with what you believe are the valves not being fully opened, but the only time the valves are fully open is Track, so I guess all other modes you should also never go wide open?
I have gone wide open numerous times with my exhaust set on quiet, no problems in 6 years on my 2020. My 2017 GT had an aftermarket active exhaust with two settings, either valves all the way open or all the way closed. Went wide open a bunch of times with the valves completely closed and in almost three years of owning it, no issues at all.
Going wide open in quiet mode won't hurt anything. Going wide open is only for a brief time, usually accelerating up to a certain speed then letting off. Of course, I would also never drive hard in quiet mode for an extended period of time, but on the street for an occasional burst of wide open, no issues as far as I am concerned based on my experience.
To the original poster, as others have said, should be able to set quiet mode starts for 24 hours. I have mine set from 9pm to 9am. Don't remember the exact screen since it has been years since I messed with it, but I am sure playing the the times you can get a 24 hour quiet start, or at least close enough to 24 hours.
Doug
Keeffa
australia
keith
ford mustang 2018 gt
I had mine set to start on quiet for the full 24 hours but sometimes it didn't work and would start on normal. So I set it to quiet from 7:00pm to 5:00pm and it's been fine with that. Then I have MyMode set to sport and race for exhaust, for when I want to play.
TonyNJ
Northern NJ
www.instagram.com
Tony
Doug
Hey, Straw Man. You write in a lot of absolutes, "Never, Always, Exactly". Please don't take my post and twist it into some Sith Lord shit. That wasn't the context of my contribution to the OPs post.
That being said, you also pretty much validated my point right here...
Glad your valves held up. I've had rattling AE on a 2019 GT PP1 and a 2020 GT500 Track car. Those actuators and valves went bad somehow. Maybe I'm just unlucky. Regardless, I'm sharing my experience with the OP. I don't need you to swoop in and try to negate or invalidate it. He can make up his own mind.
Good night. Please don't reply. Been dealing with people like you all f'n week.
Pistol_91
Clearwater
2020 mustang GT
Well you can't just come on here trying to give out information and not answer WHY something shouldn't be done.
If you shouldn't run the car full throttle in quiet mode then why does Ford make it possible? Why is there no warning? Why does Ford scale the valves to open up more at WOT for the quiet mode table in the tune?
You can't just say "don't do it and if anyone says otherwise you're wrong!"
You stated "The OEM doesn't open via computer at WOT. It opens via selection on toggle or steeringwheel". This is incorrect. It DOES open via the PCM. The confidence you have in what you're saying knowing you don't know is wild. Why state something you know nothing about or assume? It just makes you sound ignorant.
I doubt your rattling active exhaust valves are from running it in quiet mode at WOT. Either way I don't see why anybody would run WOT in quiet mode anyhow. Like I stated before
Ford doesn't allow the valves to be fully closed at WOT in any mode, ever.
Wolfys11
New york
Jakub
2023 Mustang Gt
I keep my quiet mode from 12-12, so 24/7. All my cold starts are in quiet mode and car stays in quiet mode until i switch my drive mode to my mode or other which changes the exhaust to whatever the preset is, in my case track mode
D Bergstrom
North Las Vegas, NV
Doug
2020 Mustang GT
Sorry, haven't been on here all week, but I will reply if I want to. Funny you say I am dealing with absolutes, aren't you doing to same thing? Look at your first post in this thread, doesn't get more absolute then that. I am also sharing my experience with the OP, it just so happens to be the opposite of your experience. Same as you, I am offering him another opinion, he can make up his own mind. Sorry you have had issues with your valves, hopefully you can get it figured out and keep enjoying active exhaust, I feel it is a great feature for our cars.
Doug
D Bergstrom
North Las Vegas, NV
Doug
2020 Mustang GT
I love the sound of my exhaust in track mode, and 95% of the time, I enjoy the crap out of it. (Both the former OEM exhaust and my current Borla ATAK.) Sometimes through, I just want quiet, but still want to have some fun. Place the car in track mode, then change my exhaust to quiet mode. Also, loud exhaust definitely attracts attention, so sometimes quiet is the way to go when you want to lay low.
Doug
