Question re: BLIS, lane assist, etc.
FullThrottle
Wisconsin
2016 Challenger Scat Pack, 1996 Rx-7
Is it possible to permanently disable these features on the current Mustangs without having dash lights lit and/or having to use the menu every time you start the car?
reednatron
Nathan
Ford Superduty
Lane assist/alert can be turned off, it's the button on the end of the turn signal stalk.
FullThrottle
Wisconsin
Does it stay off permanently?
This is a serious question for me. I travel a good bit and get a fairly wide variety of rental cars, and there are few things that I find more annoying than a setting that doesnt stay changed after I've changed it. As a result of this control characteristic, I won't be buying another Challenger, and am thinking about returning to a Mustang....but not if it does the same thing.
reednatron
Nathan
Ford Superduty
yes
86pagt
Virginia
Dale
2019 Ford Mustang GT
The button on the stalk and also in the menu you can deselect them
FullThrottle
Wisconsin
I notice that there's no option to turn off "pre-collision assist". How do you disable it permanently?
Torched10
Atlanta
Bob
Why woukdvyou want to turn off collision alert.mine had only gone off twice in 3 years and both times it was a deer.if it wasn't for collision alert is have hit them
FullThrottle
Wisconsin
"Assist" =/= "alert".
Torched10
Atlanta
Bob
?IT Does WAY MORE THAN ASSIST.if you're not on you're brakes quick enough it'll stop the car..hetes explanation
The Pre-Collision Assist feature uses camera technology to detect a potential collision with a vehicle or pedestrian directly in front of yours during day or nighttime driving. * It can help reduce the severity of, and in some cases can eliminate, a frontal collision.10 If a potential collision is detected, an alert sound is emitted and a warning message displays in the message center. If your response is not sufficient, Automatic Emergency Braking (AEB) will precharge and increase brake-assist sensitivity to provide full responsiveness when you do brake. If you don’t take corrective action and a collision is imminent, brakes can apply automatically
86pagt
Virginia
Dale
Select Pre-Collision and it takes you to where you can uncheck and set alert sensitivity.
Some Random Guy
WA
Jeep Wrangler
Vehicle height also messes with calibration of the system. Less an issue for a mustang, but be aware if you have to get your glass replaced they may not be able to certify the pre collision system if you’ve lowered your car.
If you’re lowered, the auto brakes may kick in at the wrong time.
FullThrottle
Wisconsin
Thank you - is that a permanent selection, or does it have to be re-set at every key cycle?
FullThrottle
Wisconsin
That's one good reason to permanently disable this function.
Honestly, I would pay extra to be able to buy a car without all of this nonsense.
