Question: Paddle Shifting w/ A10
Bravo
New England
German Turbo Box
So paddle shifting with my current DSG is quite enjoyable - the shifts are quick, and the 6 gear setup makes shifting feel as close to driving a manual as I'm going to get without adding a pedal to my setup.
My question is, do you find that paddle shifting on the A10 to be awkward, in that you have so many gears to go down through?
With a 6spd, I can be traveling on the highway, double tap the down paddle, and instantly be in the power band in 4th gear.
With the A10 having a ton of overdrive gears, I would imagine the scenario being: Cruising in 10th, tap tap tap tap, accelerate and overtake.
Any chance that the paddles automatically skips gears?
Allerick
First Time Mustang Buyer
Baltimore
Andrew
2016 Mustang (DIB 2.3T w/ Ceramic Int.)
Good question. I am curious to know the answer to this as well.
Matco
Camarillo Ca
2019 F150 2018 Mustang GT 1996 Ford Bronco
Your probably going to better off leaving it in drive or sport, it will automatically shift from 10th down to 3rd when you mash the gas faster than you could flip the paddles
itguy08
2018 GT Premium, 2010 Taurus SHO, 2011 F150
In my SHO if you're in Manual mode and nail it, the trans will downshift as many gears as needed for you and it's up to you to upshift. Does the Mustang work the same way?
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
What this guy says.
Hivel
NorCal
Mustang GT
Agreed. The paddles are useless when in shifter is in “D”.
I shift from “D” into “S”; when, I want power to pass. But, that will put me in manual mode if I tap a paddle. I want the drive mode to switch to “S+” when I tap the down paddle while shifter is in “D”.
Cheers,
Bravo
New England
German Turbo Box
So it sounds like paddle shifting doesn't work so great on the A10? I wish there was a setting that would treat it like a 6 speed (probably something like 1-2-3-5-7-10).
wanted33
Down South in Dixie
Jim
2018 GT Convertible, 2006 GT Coupe
If it's like the sport mode with the A6 in our '13 it should downshift itself when needed, or wanted. It would odd if Ford didn't design it that way. I possible how about one of you lucky folks that have an '18 already give it a try. Mine hasn't been built yet. Thanks.
Matco
Camarillo Ca
It works great but if you want want it to drop 6 gears fast you will have to click more than twice...
chunter415
Seattle area, WA
2018 Mustang GT PP1, 2019 F150
With the A10, its not worth the paddle shifters, I only use them to down shift from time to time if I want it to auto rev-match to help me slow down or make more noise. Driving it while speeding up means your always shifting and requires a lot of looking at the gauge to keep an eye on your tach and speed.
Overall its a great transmission and I love it, but buying it I thought I would be able to use the paddle shifters more, and nope not the case. Leave it in D or Sport + and let it do what it does and you'll be happy.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
I would think the paddles are only useful on a road course. But I'm just guessing
10r80
Dallas
2018 GT
Same.
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
Imagine a 10 speed manual. Yeah… no. Just too many gears to shift manually and not enough time between shifts. As others have said, I use it occasionally to downshift if the A-10 doesn’t seem to want to, but otherwise it’s just too much work.
DickR
Raleigh
I'm assuming that paddles will be best for typical autocross using 1, 2, and 3 as appropriate. For a road course track similar but primarily using 3 - 6.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
The A10 has 3 overdrive gears. That's pretty normal nowadays. AGA0E (LC500 trans) 1:1 is 7. 10R80 1:1 is 7. ZF8 1:1 is 5. TR6070 1:1 is 4. And so on and so forth. Look ahead and plan as much as you can. In an actual manual you kinda have to be doing that anyway but at least you have one less movement to make.
