Question About Traction Control
IrishStallion
Missouri
18 gt mustang
There is a little plug next to airbox and fenderwell. It’s the only way to release the beast. lol.
WD Pro
United Kingdom
Lime GT
How about finding an empty lot and letting it rip - if you do dumb things so you know for sure the electronics are kicking in, at least you then might know for sure if it’s the same intervention you are seeing on the street :like:
WD :like:
Wheat392
Michigan
Bill
2019 Mustang GT PP1 MT82
So today, I was leaving my parents house, start it up and drive down a couple side streets to get to a main street. I get it straight for a few seconds and then start to accelerate, and the car did it again, like it bogged down like I was hitting the brakes for a 1 or 2, then it sped up. I was only increasing speed from 20 mph to around 45. I didn't see no traction light flash or stability light, I'm not sure it may have a light. I also asked the dealer about traction and stability control and I don't think they understand my situation with my car. They believe I am giving it heavy throttle off a turn or something and I am not. Anybody got any idea whats going on?
a thought,
being mass airflow cars, was the K&N CAI a “no tune required”? If not, the larger CAI will slow down the air velocity, the sensor will read low and the car will bog without a tune update.
if it’s a no tune required, make sure the mass airflow sensor is installed and connected securely and there are no air leaks before the throttle body.
best of luck!
Rod27
St. Louis, Missouri
2018 Ford Mustang GT
a thought,
best of luck!
Thanks,
Its a no tune required. I'm going to check this right now.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Doesn't that also kill the ABS? Anyways, OP if TC or AT is kicking in, the indicator will start flashing.
IrishStallion
Missouri
18 gt mustang
Does not seem to kill abs on mine. I have hammered my pp1 brakes many times over 100 mph with zero signs of lockup. Driven close to 10k miles unplugged no problems...
Rod27
St. Louis, Missouri
My car didn't have a incident with this in couple weeks, but I do have a question so I can monitor this. Is there a way to see my Oil Pressure in a Base 300 A 2018 Mustang GT, I was trying to find the Oil Pressure and the Vacuum Screen but only able to find the vacuum gauge?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Dfeeds
Illinois, US
Was it like a stutter? Sounds like misfiring to me. A vacuum leak could be responsible if there was one after the install. Bad gas could cause this as well. But what you're describing there is different than how I'd take the first description.
What I'm talking about would feel kind of like if you shifted into 6th gear way too early, floored it, and felt the car stutter and nearly fall on its face.
Wheat392
Michigan
Bill
Thanks,
many of the no tune required CAI’s have inserts that neck it down to factory diameter so the sensor reads right. If the diameter around the sensor is larger than stock it would need a tune or the insert put in.
