Puddle light.. help!
npole
Italy
Mustang Bullitt 2019
So this.. did I bought the wrong part (because there's mirrors with different slot angles)? 😭 ...or it is defective?
blackk3389
port st lucie, florida
WILL
'19 BULLITT#3389, '03 cobra vert#2198,2023 F150
Can't be the other side either from the looks. is it aftermarket or from FORD?
npole
Italy
It's ford OEM, I know there's like 3 different mirrors types (blind spot.. non blind spot.. whatever) I didn't expected the puddle light to be angled in a different way.. unless this is really defective, so before yelling at the seller, I wanted to be sure...
Goterr0r
St. Louis
Chad
2022 Mach 1
Could it just be the angle you have it installed at? Like adjust left or right to get the pony to center on the ground. It seems like that could be it based on your picture. I've never taken these out, but an aftermarket set i had in my 2014 years ago i had to spin it until i was happy with the placement on the ground before i secured it. Unsure its the same as OEM, but just throwing it out there for ya.
ralph7
Houston
2000 GMC Sierra 1500, 2019 Mustang Bullitt
No ass light meant for the non v8 cars. :crackup:
MrBD1348
Chicago, IL.
'22 GT MT-82
the OEM ones snap into place and are fixed alignment
npole
Italy
Nope, as already said.. you can't rotate it, it just snap in.
Dler
Indiana
Darryl
2023 Mach 1 HP
I know the aftermarket ones have an adjustment tool to readjust the logo. pimpmyev.com makes them for my Mach 1 and the install video shows how to adjust the logo……not sure if it’s the same on the OEM
npole
Italy
Yes i know, there's two gaps in the aftermarket ones who let you rotate the internal lamp.. it's not the case with the OEM ones (like this), and they are sealed, unless you break it there's no way to "mess" with the internal components.
However apparently it looks like it is faulty, the vendor agreed to refund me.
But now the problem raises again, there's like 6 different codes for this puddle lamp, and I'm getting confused of which one will fit mine: Bullitt (EU) with heated mirrors (no blind spot signal) and power closing (or whatever it's called the electric closing feature).
I don't want to buy another one, to find that the previous one wasn't faulty after all (whenever I've got the refund) but the wrong part.
djcodeman
Austin, Tx
2015 GT roush SC
Mine looks the same. Can't be adjusted. It's a China knockoff pretty sure.
npole
Italy
If they "cloned" it, they did it pretty well, it's identical to the the original one, i mean same (external) materials, it does even have the Ford QR code applied on it, and the horse (despite the wrong rotation) is just perfect like the OEM one (compared with the one on the other side). I deffo don't think it's a "china fake part"... but you never know these days.
Yours was apparently identical to the OEM part?
