Procharger issue
BBW P1X
Arizona
15 Mustang GT
Vibration towards the drivers side. I have done just about everything i can think of and im ready to give up. I am having a vibration/bog noise that i can't seem to find out what it is.
tensioner has been replaced, i upgraded to an ati balancer, with ati crank pulley, i upgraded oil pump gears and crank sprocket since i was already switching all that out. The head unit has been checked by procharger and they said its fine. Oil has been changed on the head unit, engine and spark plugs are new as well. It happened when i started installing my boost gauge. The shop tapped into the passenger side fuse box in the interior. Any ideas or clues? The shop installed all those items i stated except the tensioner which was myself. Im lost...
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Do you have a way to record and share whatever you are experiencing?
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Wait, it only happens when you're moving? Have you inspected engine movement, drive train, etc? You said it's a vibration and only when you drive, I'd start there.
BBW P1X
BBW P1X
Arizona
15 Mustang GT
Wait, it only happens when you're moving? Have you inspected engine movement, drive train, etc? You said it's a vibration and only when you drive, I'd start there.[/QUOTE
Here it is, hard to feel and well maybe motor mounts? I doubt it, wouldn't my header install need to have engine mounts loosened and retightened? I don't know if its the wheels either, i have a set that are brand new, i'll put them on and see if it continues
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Hard to distinguish on the video, you were right about that. Car sounds good though. Yes, your engine mounts would have been removed for the header install. Do you have clearance on the passenger side frame rail/ac line and the header?
TGGT
SoCal
2018 mustang gt
I would be most suspicious of a motor mount or header clearance issue. I’ve done several header installs on these cars and there’s several places they could rub or make contact
BBW P1X
BBW P1X
Arizona
15 Mustang GT
i will take a look at it in a little and see on both sides, the headers were installed by a shop and the problem was still going on before and after, i'll check them and see if possibly messed up.
BBW P1X
BBW P1X
Arizona
15 Mustang GT
I will check headers as well to see if rubbing or anything and post a picture
BBW P1X
BBW P1X
Arizona
15 Mustang GT
mounts are tight and fine, the headers aren't touching anything either, any other suggestions?
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Zero disrespect, but if you hire shops to do your installs.. I'd maybe hire of one them to evaluate the car and the safety of it.
BBW P1X
BBW P1X
Arizona
15 Mustang GT
well problem is i have zero to no time to head over to the shop to get it checked due to working at home and thats why i can check the vehicle myself. I am going to take it in when i have time and see if he has suggestions.
SheepDog
Colorado
Dax
I will attempt, take in mind im on headers so it may be difficult. Only ahppens when i drive
Bent wheel? Separated belt in a tire? Driveshaft issue? Wheel bearing? Does it change with engine speed, or vehicle speed? Try going into neutral while the car is moving down the road and see of the noise changes or stays constant
SheepDog
Colorado
Dax
Or are you talking about the clunk noise right at the end of the video?
