Procharged 2014 overheating issue HELP NEEDED
Basspro302
Ohio
2019 mustang gt
If you have gone threw everything sounds like an air pocket from a blown head gasket or crack in the cylinder and or cylinder head. Leak down test with the radiator cap off and block test. Just had a car in same issues passed a block test but leak down tested and found it pushing air in the coolant although it was a 3.5 ecoboost. Car had no misfires no signs of anything besides overheating. Also check the fan resistor, they are know to burn up on the gen1s my low side would work but the terminal for high speed burnt up.
luc
CA
2017 GT with PP
That is incorrect
That is incorrect and not the purpose for a thermostat that is incorrect the purpose of a thermostat to keep a engine at operating temperature. Without the thermostat your engine will increase and decrease in temperature based on ambient conditions
A t-stat control the minimum engine temperature, not the maximum
Once the t-start has opened , the maximum temperature is controlled by the system Btu’ s capacity
fuelforfire87
IL
2014 Shelby GT500
I didnt even know an s197 cant use the stock fans and radiator with a procharger...
You can use the stock radiator but the fan gets replaced with whe fan shroud in the kit.
Rapid Red
Woodstock GA
Greg
Let’s say you have a 170 thermostat at 170° the thermostat is wide open it doesn’t regulate it doesn’t open and close “it’s just wide-open. it will not close again until the temperature goes below 170 then it will close and allow the temperature within the engine to rise back up to 170 before opening again. If you are above 170 it will never close. So above 170 it is exactly the same as not having A thermostat
NO it IS not....
The thermostat has a built in restriction. I am sure you have seen that, no ?
@ full open it is STILL slowing the coolant flow so it can dissipate heat as it travels.
Coolant entering the core is hotter from the block. @ the pump it has less heat.
Just the way it works.
Jackson1320
California
Jaxson
2015 mustang gt
A thermostat controls minimum operating temperature and without one the temperature will depend on the temperature outside but will run cooler the BTU will determine the overall capability of the system. correct
Jackson1320
California
Jaxson
2015 mustang gt
NO it IS not....
Never mind you don’t get it and I’m tired of teaching class
Jackson1320
California
Jaxson
2015 mustang gt
I don’t think it has a blown head gasket because it doesn’t get all the way hot just really warm. With a blown gasket it would just continue to get hot. I’m confident it is a lack of air flow
Procharged 5.0
Las Vegas
WILLIAM
2014 procharged mustang gt
I really hope you are right. I looked under the car and it is missing the air deflector. But with cylinder heads temps still getting over 210 just idling i'm not sure that's my only problem. Maybe I also need a fan upgrade along with the air deflector reinstalled.
Basspro302
Ohio
2019 mustang gt
Well i’m not there to diagnose it in person. So cht never goes over 240
Then?
go buy a fluke meter and thermocoupler and get a real reading, check the iat, ect, and ambientair temp sensors after a cold soak make sure they read within a few degrees.
Ive had cars with cracked heads run hot but not overheat. The new escape with the 1.6 has done it to be before. It can happen and does.
Procharged 5.0
Las Vegas
WILLIAM
The heater extracts enough heat by itself to keep these cars cool while idling. If you are cruising down the highway and kick on the heater and your temp doesn’t move down, your radiator isn’t the problem.
You can throw money at this but you need to start at square one and use the process of elimination. It’s probably a simple problem.
Have you checked the inlet side of the water pump to see if the hose is collapsing? Easiest way to tell again is turn on the heater with a thermometer in a vent and see if the air starts to cool down after sitting and idling with the heater on while it’s in the very hot range.
I have not tried turning the heater on while driving on the highway. I live in vegas and its been over 110 degrees outside haha. I turned it on while idling though and it didn't change the temps any. I don't believe its the radiator because it was already changed.
I have already checked for a collapsed hose and all is good there. I went over the basics before I started changing parts. Trust me i'm tired of throwing money at it.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Do you even have heat? These cars have a tendency to trap air pockets in the heater core when you dump the coolant which causes a significant flow restriction near the CHT sensor.
Procharged 5.0
Las Vegas
WILLIAM
Yes the heater work just fine.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Welp, pretty strange then. Best guess is that you have a blockage somewhere, or a compression leak into the water jacket somewhere. Compression test won't necessarily show it either, you need to do a leakdown test on all the cylinders.
