morgande
- Oct 24, 2016
- East Coast
- 2017 Mustang GT PP Ingot Silver | 2013 Ford F150
I have a 17m GT PPPremium with 400a. Trying to research the best upgrade path for the audio system. Specifically with respect to replacing the stock amp
Far as I can tell I have 3 options:
The other main difference is that #3 does all the CAN bus interpretations for you while 1 and two will require a FORScan code.
If I did use 1 or two, what happens with the center chanel? If I use CarPlay navigation or built in Navigation do I get the same feature? Aka does it automatically attenuate the music while navigation directions are issued? And does the voice navigation go to the center chanel or across all speakers?
And I am curious just how many people retain the center chanel when doing an upgrade.
Finally, if you did go the DSR1 route, what was your experience with it? How hard is it to switch presets?
- Use the iDatalink harness and convert them to RCAs
- Buy a custom version of #1 but has shielded balanced inputs.
- Use the iDatalink with the DSR1
