PP Strut Tower Brace kit + Cowl Extension + Lower K Brace Install Guide
Atticaz
Arizona
2017 Mustang V6
Wow. Just installed the extension bracket. IT…. IS…. Required.
I just didn’t notice when I initially installed the firewall brace just how flimsy the rear mounting point really is!! You can’t really call that the true firewall. This bracket really ties in that flimsy wall with the true firewall.
Can’t wait to take her for a drive later
FYI. I used two flat pry bars to gain access. I used the weight of the firewall brace to hold pressure on the left side.
Atticaz
Arizona
2017 Mustang V6
I took a short video of how it goes in.
thompsje
MA
Jeff
2018 Mustang GT Premium
So, I just did this today, and it was a pain in the ass... but not complicated. The only thing I wanted to add was that when I ordered the Extension Panel, I also ordered 4 of the Cowl Panel Bolts. If you only order 3, it allows you to tie into the rear, but then you only get 2 bolts that go through the Extension Panel and Brace and into the front piece of the "firewall". There is a threaded nut on the front of the Extension Panel that I don't think the AR kit came with a bolt for.
The arrows point to the nut on the extension and the way it looks when passing through the brace. It's kinda hard to describe, but maybe the pictures will make more sense. This is the only bolt that directly attaches the extension panel to the larger cowl brace.
Atticaz
Arizona
2017 Mustang V6
Yep. I got the four bolts as well. 👌🏼 Anyone missing the panel is missing out. It’s so worth the trouble.
James1980
Poway, Ca
Jim
2020 Mustang GT
I just installed everything the OP posted on my '20 GT base. Wow what a difference.
Thank you OP and everyone else that contributed to this thread. Pretty straight forward install. Not easy, but not too difficult either.
Highly recommended
wtsnowman
Houston
Anthony
Can you mount the extension panel without removing the strut tower brace and cowl brace?
James1980
Poway, Ca
Jim
2020 Mustang GT
Like mentioned, no you cannot install it without removing those two items.
The extention panel goes under the cowl brace, it goes in at a fairly extreme angle so no way to slide it under. And since the cowl brace sits under the strut brace, that has to come off as well.
Dont let that discourage you though, its worth it. Follow all the tips in this thread and you'll have no problems
wtsnowman
Houston
Anthony
Thanks! I've yet to install the strut brace and cowl and the extension is on order. I'll probably just do it all at once when the extension comes in. It'll be the most efficient use of nylock nuts haha.
I already have a PP S550, so just contributing to this by adding the original Ford Performance PDF in the event anyone needs it in the future.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
That kit is missing a very important piece.
FR3Z-63016A52A
Atticaz
Arizona
2017 Mustang V6
shadowx
Missouri
mustang gt premium 2019
anyone knows which hardware I need (the 2 extra ones) for pp belly pan conversion got 2019 base gt?
MRGTX
CT
2020 Mustang GT 6spd base
Page 1, post 1 has the complete BOM. Did you check that?
