Please Do Not Run E-85 on Stock Injectors.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Will changing to the 47's require modification of the tune?
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
CEHollier
Prairieville, La.
Charles
Lonmon
Mid East US
2018 Mustang GT 10spd Base
Um, changing from stock injectors to 47's will definitely require a tune change. Consult your tuner before installing the injectors to make sure you have the correct tune for them.
Chameleon
Gold Sponsor
www.ebay.com
Really. I thought it was just for the E85 revision.
Lonmon
Mid East US
A larger injector will require the tune to be properly scaled for that size injector. The larger injector will require less pulse width to spray the same amount of fuel to keep the air fuels correct. E85 can change things as well. The tuner should know about the injector size as well as fuel type for a safe correct tune.
CEHollier
Prairieville, La.
Charles
Appreciate the response. I'll contact Lund before doing anything. Running E85 should I see any improvement in performance? Not expecting anything radical.
Soonertim4
Spring, Tx
Timothy
2021 twister orange gt performance pack
Getting ready to purchase my christmas presents:headbang:
Goin to go ahead and order the injectors to be on safe side.
Will there be any issues of running 47lb injectors on 93 or returning back to stock?
Need4Speed15
Parkland, FL
2015 Magnetic GT Auto
If you have a Flex Fuel tune for the 47's there will be no prob running E85 or 93. If you want to return to stock you will need to put the stock injectors back in.
Terminator2
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
Definitely the car would run really rich on the stock tune on those injectors. About 25% rich to be exact.
Soonertim4
Spring, Tx
Timothy
Thanks guys
Chach805
Port hueneme, ca
2015 C/O w/ PP
I have the Flex Fuel Tune from Lund. I noticed the cold start starts up like crap with E85. Would the 47 injectors fix the crappy cold star or the injectors have nothing to do with it?
Soonertim4
Spring, Tx
Timothy
Thanks for the info Terminator
Jus ordered my injectors
Terminator2
Terminator2
Spring Hill Florida
David
I'm assuming you mean it cranks longer on cold starts vs 93? Nope injectors themselves won't but adding more cranking fuel mass and cranking spark helps some. It still won't be as quick to start when it's cold due to the nature of E-85 (high ignition temperature).
