Pilot bearing removal?
Corey_cars
Toronto
Corey
2015 mustang gt
Just about to swap the clutch in my car to a LPXHD, Lightened steel flywheel, mgw x spec flat stick, mccleod clutch line and high load pilot bushing. Had enough of the lock out issues and sloppy shifts so I'm changing it all, my question is what tool and method do you guys use to remove the pilot bearing in these cars? Just trying to make it a headache free install of everything. Thanks guys
I Bleed Ford Blue
North East OHIO
They make an attachment for slide hammers to pull a pilot bearing/bushing. Or you can pack the center hole with grease and hammer a steel or brass rod in there. The grease will act like hydraulic fluid and force the bearing out.
Corey_cars
Corey_cars
Toronto
Corey
2015 mustang gt
I've done the grease trick before and the toilet paper, somebody told me that doesn't work on these bearings. Thanks for the advice
MyStang
Michigan
2015 GT
Your local AutoZone has the pilot bearing removal loaner tool.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Will pizza dough or an Everything Bagel work too? 😆
It might! Ive seen and heard of folks using all kinds of materials with varying success. I always use the slide hammer tool.
Shifting_Gears
South Florida
Make it easy and get a jaw puller and slide hammer.
The old school tricks CAN definitely work but to a varying degree of success. On my old 4.6 GT I tried a couple and ultimately ended up getting a puller after driving myself insane LOL.
Bitten in '69
Round Hill, VA
Fred
19 GT350, 22 Ecoboost HPP, 90 GT, 82 GT
The old school solutions work great, on the old style solid brass bearings. On the newer roller bearings, not so much. Use a puller on the roller style.
ZPD
TX
2017 GT Premium
I just borrowed a puller from Autozone.
BTW, I have the exact same setup.
Bobn57
New Jersey
Bob
1968 Mustang Fastback, 2021 VB, GT/CS
That’s how I used to do it. Pack the center hole. We used to use dum dum which was like thick putty. That’s what we called it. 😁 It worked great. Grease is probably much easier to clean out.
