Sent you a PM.I want to upgrade my Roush HE water pump to the Pierburg CWA 100. VMP has a harness for the Cobra and was wondering if that harness would make the Pierburg plug-and-play for the Roush?
The Pierburg CWA 100 flows nearly twice as much as the VariMax.Just run the VariMax 410110 DC brushless intercooler pump, it's the same pump Edelbrock and Whipple use, think it's the same one VMP uses now as well.
Check out Dept. of Boost website. It does into great detail as to why more flow is better.For those who have done this, what differences are you seeing in iat2 temps? I have trouble wrapping my head around why moving the exact same amount of coolant more quickly is a big advantage. Is the idea that the coolant will go through the IC more quickly....and thus pick up less heat? Won't it also flow through the heat exchanger more quickly....and not be cooled as much? It seems that those two things would equal out.
I am not arguing with the logic of doing this but would like to understand it better.
I have not cracked that nut yet but I will. The VMP harness did not work so I will figure out what pins are needed to get it working. I do know that pin 1 is ground. Waiting on some stuff to arrive in the mail.I'm looking to do this very thing. If you can please share what harness and/or adapter is required to make the Pierburg work with the Roush harness, it would be greatly appreciated!
Jason from department of boost provided me with the best info in an email.... here it is....Check out Dept. of Boost website. It does into great detail as to why more flow is better.
I was thinking the same, but I think DOB could answer that better.I wonder what good is a “system” that has a larger heat exchanger and 1“- 1 1/2“ lines if the inter cooler inlet/outlet remains at .75”? Wouldn’t this restriction render at least the larger lines moot?
