how noticeable is 100 torque on a car ?
ProChargerTECH
Boostville
2015 Mustang(s)
Average power, and Average TQ wins races. Also, having the peak TQ located in the proper RPM area. If it was just all about TQ we would all be building Diesels.
Nobody gives a poop about TQ at 2,000 rpm when the car has 10 gears and lives at4,900+ RPM once your foot goes down on the loud pedal. :). #hardfax
INBEFORETHEHATERS: yes, launching with more TQ is awesome. But thankfully a converter swap can make miracles happen. :)
SolarFlare
S. Fla
2015 CO GT
:clap:
ProChargerTECH
Boostville
2015 Mustang(s)
I just bought a 2017 for myself, to basically do a build similar to yours.
- P1X (but on the Carb EO bracket)
- E85 (supporting fuel system)
- Converter
- GT350 Intake
But I am weird, and want to run it through the stock exhaust :). I talk on the phone while driving A LOT!
SolarFlare
S. Fla
2015 CO GT
- Converter
- GT350 Intake
Very happy with it, extremely reliable but we’re on the same boat as far as exhaust. I’m getting too old for noise. I have a pair of active ‘18 mufflers in the garage that I want to put on and remove the magnaflow competitions. Will allow to me to go quiet and loud as I please.
engineermike
La
2018 GTPP A10
I got the David Vizard auto math handbook in high school. It said to calculate torque to the driveshaft before and after the shift and adjust shift points until these numbers are equal. Years later after engineering school, I learned you really want maximum average power so you would shift an equal amount over the peak power as the rpm drops under (if peak power is 7500 and it drops 1000 on the shift, then shift at 8000). I thought one of these must be wrong. Turns out they yield exactly the same result.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
How noticeable is 100 ft lbs of torque?
Ever been punched in the face real hard?
Coyotes55086
Coyotes55086
Canada
Anthony
2017 Mustang GT
screwed I my lsst post
I wanted to thank you
because for some odd reason something just hit and made sense all of a sudden
when u said " Nobody gives a poop about TQ at 2,000 rpm when the car has 10 gears and lives at4,900+ RPM" . I realized what u meant..and it all made sense. so I guess like myself , I love the pd blower because it slaps you with alot of low end torque . which is something I like because I feel the cage lacks it . maybe not in 1st gear ..but torque added higher up in the rpm range will pull you harder on the highway runs
