Performance Brake Pads - New Rotors Needed?
buffetraider
Missouri
Jack
2019 Mustang GT Premium
I've got a 2019 GT Premium, currently all stock except for the suspension which I replaced with the Ford Performance shocks & struts when one of them sprang a leak. Looking at getting at least a small upgrade over stock for my brakes and I was looking at this Powerstop kit:
https://shop.advanceautoparts.com/p...+brake+pads&selectedFulfillment=home_shipping
My question is, is there any problem with getting just the Powerstop brake pads at first? There's no noticeable wear on the current rotors (only 14k miles at this point) and I've only put it on the track about 6 times over the last 18 months. Really just looking for insight as to whether it's going to be fine to keep the original rotors or if the full kit with rotors is worthwhile. No plans to increase track time beyond 3-4 times a year at this point.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
No issue running the pads on the stock rotors. A few heat cycles and seating them and should be good to go.
snake bite
Australia - Adelaide
Fords of course
Yeah no need to change the factory rotors, just do the pads. I think the power stop pads are better than the OEM. Then consider upgrading the rotors to slotted etc when the OEM's are done. That's what Im going to do.
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
Powerstop pads are terrible and a downgrade.
robvas
MI
2011 GT
Stick with solids. Especially if you're going to something like a PowerStop or other generic slotted/drilled rotor.
