marctallman
http://imgur.com/a/sB7yC
This is the only one I have a pic of. I have the print outs in my car but ill need to get them in the morning.
Im using 91 octane at 784 ft above sea level.What's your elevation and what octane gas do you use. Maybe the dyno wasn't corrected for sea level? The way I understand it, dynos usually do some sort of conversion to display what your car would see at sea level, maybe yours was reporting what you were actually getting at your elevation?
I just ordered a boost gauge so if I dont get it figured out in the next few days Ill see how much im pushing.Yeah you need a boost reading from the dyno or a boost gauge to really see what's going on.
No I dont.Your car should make over 600whp on accident with that setup. Do you have the lund boost box to log boost? If not the log wont show.
My blow off is extremely loud and when I let off the throttle I notice a huge let off of power so I feel like boost is definitely building and getting through my system. Did you have it tuned by lund?I had a issue similar to this and the tune file was corrupt. Car seemed like it was making boost but the car didn't feel powerful. It was a night and day difference once we figured ot it was the tune and not s mechanical issue.
Same was happening to me but for some reason due to the corrupt tune file the imrc's were staying closed not allowing the motor to see all the air. Car sounded fine and built boost right. You can also check your load on a datalog. If your car is actually seeing 8-10 lbs your load should be 1.35-1.45. Right now I'm seeing closer to 1.61 on load at 12 lbs and before with the issue load was only at .80. This will tell you how much boost the motor is actually seeing. Just throwing out something that happen to me. I'm tuned by PBD but him and Lund use the same sct tuning software.My blow off is extremely loud and when I let off the throttle I notice a huge let off of power so I feel like boost is definitely building and getting through my system. Did you have it tuned by lund?
I was having an IMRC issue so Lund told me to take it off. When I did that he said that it improved.IMRC issue? A local guy dyno'd similar numbers with a blower but he was having IMRC issues. Did the IMRC delete and had Lund retune it and it's solid.
Time for a new dyno run... :cheers:I figured it out! The coupler that connects the intercooler to the piping came loose. I was surprised that it even ran given that it was completely off. Thanks for the help though guys!
Just went back for shits and giggles to look at my last datalog.If your car is actually seeing 8-10 lbs your load should be 1.35-1.45. Right now I'm seeing closer to 1.61 on load at 12 lbs and before with the issue load was only at .80. This will tell you how much boost the motor is actually seeing.
Procharger must be different. I've got 1.92 up top.Just went back for shits and giggles to look at my last datalog.
Im at 1.86 on load at 7000 - 7500rpms and showing 11.5psi of boost??
Weird. I'm still on stock intake manifold and at the time still had stock catback so maybe that's why I'm not seeing as much as you guys. Maybe my elevation being 4000ft above seal level may have something to do with it also. It's clear both of your cars are pushing a lot more air then I am. I bet they pull hardProcharger must be different. I've got 1.92 up top.
http://www.datazap.me/u/venumous/pc...a=7-8-11-16-20&trim=0&tmin=341.49&tmax=348.33
