beef cake Paxton special numbers??
OXFORDS550GT
Virginia
2016 oxford GT white premium black accent
What psi are you seeing?
Those fuckers told me they don't read psi so I have no idea. Should be 10 pounds I think with the 3.6 pulley
z06psi
Evans, GA.
Andrew
The pot stirrer
I don't think the 2200 and the D1SC are quite comparable though but the r.p.m. is probably the main reason.
OXFORDS550GT
Virginia
I figure they were close enough if I'm not mistaken the d1sc is 1400 cfm and the 2200sl is 1450 cfm
beefcake
Bethel
2018 Ford Mustang
they are pretty close
zaquhree
Orlando
2015 S550 GT
Looks like a leaky bov or boost leak...car could be pulling timing. Look at your logs and you'll see a trend around the dip
OXFORDS550GT
Virginia
When I floor it vacuum goes to zero Immediately. What's a good indication of leaky bov or boost leak? I'm looking at my logs I'm getting -3.998 on the knock sensor from 6900-7800. What sensor do I look at to see if it's pulling timing ?
beefcake
Bethel
2018 Ford Mustang
looks like where they let off the throttle
OXFORDS550GT
Virginia
Those were logs I did on the road. I didn't have the opportunity to log it at the dyno
beefcake
Bethel
2018 Ford Mustang
i'm talking about the dyno, hard to say without the boost,
beefcake
Bethel
2018 Ford Mustang
i don't know how many they did, so it's hard to sell, when you first lift, it's still gonna be moving a tad.
i don't get too hung up on dyno's, take it to the track, that will tell the tale
OXFORDS550GT
Virginia
He let off at 7200
16MustangVet
North Dakota
2016 mustang 5.0
[MENTION=21030]OXFORDS550GT[/MENTION] damn i want to see your car on e85. your mod list is retty much exactly what i want to do. gt350 intake and na setup until i add a paxton and corn.
that combo on corn i think should be well into the 700whp range and deep 10s i hope.
JohnG
Bloomington, IL
2015 Mustang GT PP
Made 680 on 93 and 747 on E85.
Paxton Beefcake Special w/ 3.6"
JLT intake
Cat deletes
RXT clutch and lightened flywheel
Aluminum DS
Fore stage 1 fuel system
OXFORDS550GT
Virginia
JLT intake
Cat deletes
Aluminum DS
Nice numbers at what RPM are you getting those numbers for 93
Tune?
