Paxton 3.6 pulley dyno
daniel_94kg
North Carolina
2015 Ford Mustang 5.0
That does seem pretty low considering I was 674/545 on the same setup. Every dyno is different though. The track will tell the true numbers.
zaquhree
Orlando
2015 S550 GT
Stock airbox and the 3.6" doesn't work well.
isedawishy
GTPPTT6REIGHTY
Fort Worth
2015 GT
Don't most tuners have around 16 degrees of timing on 93? I wouldn't pulley down if your 93 especially if your on 12lbs with headers already. Maybe add timing if your really around 12 or add a intake that will probably give you another lb or so & around 25-30hp.
Sounds about right in my experience. On 93 I saw 16.5 degrees on 93.
Tugger50H
Tugger50H
STL
Tony
2015 GT
General consensus seems to be a little low even considering dyno variation.
Going to ditch the factory air box, cats, and retune and dyno it again. After that I guess it's a fuel system e85 and maybe a torque booster.
Unless you guys have some other suggestions to reach the 700plus power range. Have at least 4 months before the track opens up.
christian
Happy Member
Bellefonte, PA
2015 Guard GT
Sounds like a good plan Tugger!!
Jay159866
2015 GT 1966 Coupe
That will get you there. My goal is 700whp, at 613 now, E85 and 3.6 pulley should get me there this coming weekend.
beefcake
Bethel
2018 Ford Mustang
on average , no cats on 93, if the car isn't pulling timing, you should see about 650 wheel or so.
e85 closer to 750
Azmike
9's are easy!
Peoria
I made 605 rwhp on stock exhaust and E85 on a 3.8 pulley
Azmike
9's are easy!
Peoria
Spend the money an get a Fore fuel system and quit limiting your power! She needs to eat and breathe to make power!!!
dubster99
Nor*Cal
2015 Ingot Silver GT PP
This^^^
I wouldn't go smaller than the 3.6 on pump gas. E85 is the way to go if you want to go that route. Lund told me with my crappy CA 91 that if I go with a 3.6, I either have to run torco added or limit the rpm to 7200.
Azmike
9's are easy!
Peoria
You need a JLT cold air and a Fore level 1 fuel system and E85! My car runs 9's in the 1/4 mile like that. Screw the dyno i see guys claiming 900 rwhp running 10's all day. The track is where it's at! And if your going to race it a Circle D 3c stall will net you great gains for the HP to $$ ratio!
dubster99
Nor*Cal
Auto is much easier to get into the 9's than a stick car! I have a JLT/paxton setup ready to go on later this week. Eventually fuel system for me someday.
Azmike
9's are easy!
Peoria
If you build a car to straight line race an auto is the only way to go. I have had 3 Z06 for racing and this GT would rape everyone of them! I am a believer in auto only now! I used to love rowing gears but won't miss the headache of a clutch!
Tugger50H
Tugger50H
STL
Tony
2015 GT
Ignition set=your degrees of timing added. I'm thinking your around 12* with those numbers
Just got done looking over the logs and max timing was 16.5 starting around 5k and that is with it adding 5 degrees. It never pulled timing through out the pull.
BrazukaV8
Los Angeles CA
Carlo
Mustang gt PP
This^^^
I'm Lund tuned with 3.6 he never told me that. My limiter is set to 7700 I wonder why he told u that.
