Pass through dimensions
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
What is the opening size into the trunk when the seats are folded down?
Everything I can find talks about trunk dimensions.
TIA
Tim
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
Do you have a tape measure?
HISSMAN
Large Member
West Virginia
Same here.
TennTex
Frisco, TX
2017 Mustang GT-PP
TIA
Tim
Just happened across this post today... I removed my rear seats for track duty, and am looking to cover this opening without spending $hundreds on the seat deletes.
SO, I happen to have measured this and the "max" dimensions are about 42" x 18". (What I need to locate to mount and cover the entire opening.)
Understand this is actually a bit more then the actual opening, and the actual opening is a rounded-trapezoid shape. The actual opening dimension max is probably 1" or so less on each of these numbers.
Hope that is close enough and helps you!
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Thanks Steve, much appreciated!
ahl395
Allan
The opening is tapered so it is wider at the bottom than it is at the top.
Bottom is 38.5" wide
Top is 37" wide
Height is about 15" from top straight down.
Here's some measurements I've taken that may help you. (Dimensions of the side cubby holes in back of the trunk not exact, hard to measure/irregular shapes)
