Opinions on headers, Tune issues???
Carlosa_garcia
Spring Tx
2015 Mustang GT Premium DIB PP 6MT
Damn it. I may have to pull the trigger on those SP headers. Now have to either find a place that will install them cheap or rent a lift to install myself.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
same here! everyone said how horrible it would be and I never noticed anything too bad on my Evo. Maybe just a lil bit if you are sitting in a drive through, but it only smelled of awesomeness. :thumbsup:
Yeah, running catless on my Evo was amazing. It wouldn't make over 28psi with a high flow cat. Went catless and made 36psi with no problem!
Guard5.0
Indiana
2021 Rapid Red GT500 CFTP
Haven't really noticed any smell. Sounds good though!
ifly680g
Hebron, IN
Mark
2015 Mustang GT PP
I installed mine on Jack stands in my garage, make sure you have a set of flex head ratcheting wrenches. It will make it a lot easier allowing you more room to turn the nuts. You really only need a 15 mm one to get the stock headers off.
I installed Kooks with green cats and they fit perfect. They come with new hardware that is smaller then stock so it is much easier to install, 7/16 vs 15 mm.
Let me know if you have any questions.
ManBearPig
Nashville
2016 GT
Several people have mentioned a "performance connect" on these headers. What exactly does that mean? How do the collectors on these cars connect to the rest of the exhaust? Will they bolt up to the OEM connections?
I assume it takes a custom-fabricated setup to connect directly from the collector to the crossover pipe of an aftermarket cat-back?
Khyber
it's a hard parked life
Lexington/Myrtle Beach, SC
Landon
2015 GT PP CO
factory connect connects to 2.5" exhausts and oem... performance connect is for 3" exhaust. I do believe.
beefcake
Bethel
2018 Ford Mustang
oem you want factory connect, it will bolt to the factory connection point
perf connect is designed to work with that manufacturers header and their exhaust system when installing at the same time
ManBearPig
Nashville
2016 GT
Thanks for the info....
What do you want when using an aftermarket catback from another manufacturer? Still use the "factory connect" I assume? If so....how do you get rid of the smaller diameter piece between the cat-back and the header collector? Does this require custom fabrication?
Side note....is it a bad idea to ditch the flex pipe? I had a Silverado with flex pipe in the factory exhaust. An aftermarket exhaust I put on had a terrible vibration so I had a flexible piece welded back in.
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
the metal is 304 stainless on the stainless power just like the stainless works.
its not a cheaper grade steel,
SP steel is not USA source steel, its provided from the same place it's manufactured.... China.
Correct me if I'm wrong beefcake
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Well since you put it like that [MENTION=10926]beefcake[/MENTION] lol
beefcake
Bethel
2018 Ford Mustang
i typically recommend the fact connect, that way you can always hook up right away, til you go big power, theres no need to hack up the systems
if i had to guess, it's sourced somewhere in that region, but they are 304 stainless. not 409 or a cheaper grade.
cognizantphotos
Miami
Joe
China has a lot lower standards then the US though, lets be 100% real. thats the main reason i was scared over to Kooks, made in the USA, with USA quality standards.
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The only thing turning me off from the kooks is that they don't offer a 3" performance connection, at least no one has confirmed they do.
cognizantphotos
Miami
Joe
I had to get my shop to make a custom 3 inch pipe from the Kooks, to the Borla. If i had to do it again, i would do it over and over and over. Ask David from Steeda what he thinks about my setup, if i had one word for it, it would be PERFECT.
