olaosunt
I had planed to start a build thread last year for my two 2015 GT's that both had TT a some point and was going to call the thread "Twins with Twins.
unfortunately they are no longer quite twins since that track outing ended badly lol-FORD
I replaced the on3 with a 3.2 KB while rebuilding the long block with sleeve supports and GT350 heads
My Hellion car now has a 5.2 sleeved block/GT 350 heads (lost the alluminator that I replaced the stock block)
I thought I would share first dyno result of my former On3 car that now has a 3.2 KB on built engine.Car may also be on sale soon.
Details of: build
Engine
Block: Stock with sleeve supports, Main studs.
Crankshaft: Stock w/ MMR crank sprocket and MMR billet oil pump gears/GT 350 oil pump/composite oil pan-10 quart capacity.
Rods: Manley.
Pistons: Manley 11:1 compression.
Camshafts: Stock.
Cylinder Heads: GT 350 with MMR upgraded springs, modified rocker arms ARP studs.
Intake: KB 168 mm throttle body with mammoth intake.
Power Adder: kenne Belle 3.2,8 rib upgrade with 20 % ATI damper.3.5 and 4 inch pulley for 14-18 psi. Ford racing boost gauge.
Fuel System: JPC triple pump return system w/ Injector Dynamics ID1000s(ID1300s coming soon).Tuned by Lund with N gauge.
Exhaust: SW 1 7/8 long tube headers with cats/without. Cat back is custom with GT 500 axle back, pypes electric cutouts before mufflers, resonated H pipe (resonated X pipe is available).
Drive train
Transmission: Stock MT 82, RXT twin disc clutch, aluminum one-piece driveshaft, MGW shifter
Rear end: Stock Super 8.8 w/ stock differential, 3.31 gears, Ford Performance Racing Parts half shaft and Steeda “stop the hop “Suspension upgrades.
Suspension
Front
K-member: Stock
A-arms: Stock
Struts: Koni adjustable
Springs: BMR drag
Brakes: Stock
Wheels: Race-Dark star 17Ă—4.5-inch(street AMR 18x8)
Tires: Phoenix front-runners(street Mickey Thompson street COMP 255/45 18).
Rear Suspension
Shocks: Viking warrior
Springs: BMR drag
Control Arms: Stock
Brakes: Stock
Wheels: Race –Dark star, 17×9.5-inch(street AMR 18x10)
Tires: Hoosier slicks 305/45-17 (street Mickey Thompson ET R’s 305/45 18)
first Dyno pull with 4 inch pulley
Details of: build
Engine
Rods: Manley.
Camshafts: Stock.
Drive train
Suspension
Front
K-member: Stock
A-arms: Stock
Springs: BMR drag
Brakes: Stock
Rear Suspension
Springs: BMR drag
Control Arms: Stock
Brakes: Stock
