Ok… Question on bbk shorty headers
Mghoward74
San Diego
Greg
S550
There’s some contradiction going on here. If stock headers are the best, then why the need to modify them and the cats??
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
K4fxd
NKY
If you look around you can find many dyno graphs.
GT 550
Australia
Black GT MT S550
Folks aren't necessarily saying that stock headers are THE best, it's that they're the best bang for buck by a fair margin on a NA car. IIRC apart from manufacturer claims there's not a lot of evidence (any?) via back to back dyno comparisons, race times or proper back pressure measurements that the relatively high cost of aftermarket headers - I'll throw in exhausts here too - is good value. For example most people probably couldn't tell you with any degree of certainty exactly where and by how much the stock exhaust is a restriction but they're happy to spend quite a bit of coin removing or modifying it.
It's not unlike CAI in that many folks rushed to put one on their car only to find that actually the OEM one is pretty good and is a lot less hassle/cost. Again, YMMV.
K4fxd
NKY
So no flow bench data or anything tangible to be able to back that up, in other words you have no proof.
Still not sure what you are going on about. It is pretty well documented the 18 up manifold is better in the high RPM area. Properly porting it will only make it better.
Still won't gain you any low end torque.
Seems like you have a pretty big chip on your shoulder for some reason.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
I saw a before and after Dyno where the only change was from stock headers to shorty headers, and the gain was something like 1-2 hp. In other words, negligible. I can’t remember the source. I think there was a slightly larger torque increase but still single digits. You can have more hp difference between two back to back runs with no changes. Plus; to install the shorty headers you have to cut the cat off on one side of the factory header, install the shorty header, tack weld the car in place, then take it all off, weld it all the way around to the shorty header, then reinstall. Completely not worth it.
CorvZ061
Oxford, Ga
Travis
2022 GT
I'm saying there is a reason a lot of truck guys go to 18+ Mustang manifolds, because they're better. Flowbench says it moves more air at all air speeds. It's up to tuning at that point.
K4fxd
NKY
You are the expert.
CorvZ061
Oxford, Ga
Travis
2022 GT
A Dyno graph of unknown origins doesn't prove anything. You yourself said a Dyno could be made to say anything.
The graph even showed you there's some trickery going on. The key at the bottom shows a date and time for the green graph and a red graph, yet there is no red graph.
K4fxd
NKY
Believe what you want.
K4fxd
NKY
Even the dude who does the y tube vids from Lund likes the 17 gt manifold on a street car better than the 18 manifold. At least on a gen 2.
