- Feb 17, 2014
- S550 INTERIOR DRESS UP
- Website
- www.ebay.com
- 03' Cobra, 05' GT, 13' GT, 15' GT
1st at 2700, every 5,000 after that.
All at 1500 miles?!?!? Lol, you sir have yourself a hobby...Just rolled over 1500 miles (after owning my GT with PP since early December 2014 (deployments and harsh winters have kept it garaged a lot) and decided to change the oil as well as gearbox fluid (manual MT82 Chinese assembled Getrag) and differential lube due to the car sitting off and on. Ford changed the oil to Motorcraft 5W20 Full Synthetic for the coyote, Motorcraft QDC and XL18 for the Tranny (AMSOIL 5W30 was their optional stuff for warmer climates), and Motorcraft for the rear differential. No unusual particulate, debris, fine metal, or shavings found in any of the three upon inspection but I didn't ask for an oil analysis either. Still, fresh fluids after sitting off and on gives me piece of mind (clutch fluid and brake fluids next order of business along with coolant replace)
Or if the OLM says so first. My OLM will probably be at 0% by 3,000 miles anyway ... it was at 65% @ 1000 miles.Manual says 7-10k for normal driving habits. For first change though it should probably be at 2-3k.
Sorry. The engineer in me has to call this out.Got my first one at 5000k and intend to stick to that schedule.![]()
^^^ Could be 5,000 kilometers ... ie, "5,000k". Everyone knows it's not 5M miles. ;)
The "k" was for 'know one had noticed until you pointed it out' ;)Sorry. The engineer in me has to call this out.
5000k = 5,000,000
5k = 5,000
And I hate being that guy calling you out.
Thought you were a Canadian in CA.The "k" was for 'know one had noticed until you pointed it out' ;)
There are two elements that can be found in used oil which, in large concentrations, could be abrasive and thus harmful to the engine: silicon and iron. Typically, silicon in used oil is from gaskets and sealers (and in the oil itself - it's an anti-foam additive) and can be fairly elevated in new engines. It is harmless - not abrasive. Another from of silicon measured and reported in used oil analyses is silicon in the form of dirt. That is abrasive but usually pops up (with big time numbers) in older engines due to leaks somewhere in the intake tract (cracked or torn air filters, leaking old gaskets).In my lifetime I owned 13 new vehicles, cars and motorcycles. Way back when, I am 65, I read somewhere that your first oil change should be done at 1,000 miles regardless of the mfrs. recommendations. Oil filters do not remove very small metal particles created during manufacturing and internal parts breaking in.
Every oil pan of oil I drained at 1,000 miles looked like aluminum paint when you stirred it up with a screwdriver.
IMHO, that metal is abrasive. That is why when my GT premium reaches 1,000 miles I will have the oil and filter changed.
