Oil Catch Cans
70monte
Southwest MO.
2014 Mustang GT
I put a ball valve on the bottom of my UPR can for easy draining
That wasn't even an option when I got my can or I would have gotten one.
That is kind of the problem with the continued updates and improvements. Sometimes you now longer have the best.
Wayne
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Wayne
Very true.
Adding a ball valve is something you could do quite easily as you are probably aware. A trip to your hardware store should do the trick. I like it because I don't have to open the can and risk damaging O rings and it makes emptying a breeze.
70monte
Southwest MO.
2014 Mustang GT
Very true.
My can has no provisions to add a ball valve. I don't have the plug like I've seen in some pictures. I would have to drill the correct size hole in the bottom of my can and I'm not about to do that.
The ball valve setup is one thing I really like about my Bob's can.
Wayne
dev1360
STL
DIB 2016 S550
That UPR can looks like a seriously nice piece with a well-thought-out design. Combined with the check ball, it's the can to go with IMO.
Jmeo
You said member ;)
Massachusetts
Jaime
Wayne
Oh my bad, do you have the quick release can that sits behind the coolant reservoir? If so this one does not have a drain plug as you know.
I have the remote mount can that mounts on the radiator support behind the passengers headlight. It has a drain plug that can be changed to the ball valve.
70monte
Southwest MO.
2014 Mustang GT
No, my car is a 2014 and it's mounted at the firewall. When I got my can, I don't think they were offering the drain plug on any of their newer four chamber cans.
Wayne
Mishimoto
Delaware
2015 EcoBoost, 2016 GT
Mushimoto has a really nice one coming out too which in initial test have seen to perform very well
Thanks for the kind words! :thumbsup:
If you haven't already had a chance to check them out here are some photos of the internals of our catch can before and after testing.
Feel free to check out our R&D thread HERE for more info and photos!
Let me know if you have any questions, I would happy to discuss our kit.
-Sara
