PremiumT
Guest
That's not really the point of the motor now is it?Gonna be hard to really make big power with this 2.3 motor.
What do you consider 'big power' anyhow?
That's why I'm thinking catback and tune and call it a day.Well the twin entry exhaust manifold is cast into the head, many companies are doing this, it is cheaper, smaller package, less parts and lights off the CAT faster. Can't put headers or custom tube turbo manifold on the 2.3 EB.
Most EB customers will be more concerned with handling and torque curve, not "big power".Gonna be hard to really make big power with this 2.3 motor.
A translation here:This really shocked me, I thought 2015 will be built in USA and exported.
EDIT: It's confirmed
http://www.lasprovincias.es/20131205/economia/ford-almussafes-motor-mustang-201312051549.html
http://www.levante-emv.com/economia...-fabrica-motor-espectacular-ford/1057654.html
Why do you say that for? Check out what's available for VWs GTI, Audi, BMW and Mini Coopers: power level increases of 10-20% are available on just a ECU change. Then there are the exhaust improvements for cat backs available. That's just the tip of the iceberg. My guess is that at least 75 hp and torque should not be all that hard to obtain. Couple that with 2-300 lbs less weight than the V8, could be interesting. I'm not saying that the 4 banger will beat the V8 in a drag race but look out in the curves and track. I love it, so etching very interesting could be made available to us. Just quit thinking Musclecar American and think European roadcar. Just my own thoughts, of course.Gonna be hard to really make big power with this 2.3 motor.
370 HP for a 4 banger is big power. Don't pay attention to all the magazines with the 600 HP EVO, that engine can't be driven on the street. Turbos and that is all of them have a surge line, this is where air oscillates in and out of the compressor, the air is superheated and will melt the impeller into a tootsie roll, perfect for eating, but not for engine longevity and boost. I have driven a streetable B18C with large turbo putting out anywhere from 350 to 400 WHP, with not 100% absolute care I could toast the turbo and / or engine in a matter of seconds. The engine could NEVER and should NEVER see any boost unless it is at WOT and at high RPM. Once again all turbos have a surge line and the bigger the turbo the more flow and boost it needs to see to keep the blade from roasting off. :shocked: If the GF drove the car the turbo would be toast before she got to the nail shop.Not the greatest of news. I was hoping this turbo 4 would have big tuning potential
Then you never worked with large turbos and 10,000 RPM B18C engines that were "street driven", what is the rev range of the 2V 2.3 like 6500 to 7000 RPM?.... or turbo diesel engines, where it is true the blade in general does not "roast off", the shaft twist like a candy cane, and the blade bangs around on the trust bearing and ablates off against the housing kinda of like the Greek deli where the cut the lamb off the skewer.... or even more familiar barks like a dog as the blade goes in reverse... LOLNever seen a compressor blade Roasted off but I have seen a crazy post or two on the internet![]()
Hence there are NO OEM turbo application with large turbo and small engine as Joe Average would just toast the compressor by boosting the engine at low RPM, high gear loads. There is a " ported shroud" technology that gets around low flow low boost surge.
Here is a handy 400 WHP or 460 engine HP turbo calculator:
http://www.turbobygarrett.com/turbobygarrett/turbocharger
You get a GT4202 (too big I know but that is Garrett's calculator) which is about twice as big as the Turbo on the EB.
Heck you can just get to 1 bar of boost and 300 HP on the initial surge line. So basically it could only be driven at near max RPM and at WOT or the turbo would melt... just like I said.
The popular GT2876R (bigger than the disco potato) is already down hill at 460 HP, and that can't see boost under 100 HP and 1 bar under 200 HP. How high up in the rev range is that for a 2.3 liter?? Dunno but high.
Disco P to almost 350 HP (310 HP for best boost islands) : http://ep.yimg.com/ca/I/ntnsracing_2266_296331760
I can research the OEM 2.3 EB turbo but I highly doubt it is even as good as the Disco P, in terms of flow.
So no, despite what magazines say you ain't seen a "street driven" 460 HP anything at 2.0 to 2.3 liters. At least by mere mortals. Light car like a hollowed out Civic, no A/C or anything else that might lug the engine, crazy driver, super steep gears like 4.64, and a wad of cash... maybe. So clearly 600 HP EVO are like Unicorns and Rainbows. You see them or dream of them but can't touch one or ride one.
On the VNT15, VNT17 diesel turbos this was common to very common, but these turbos were crazy over boosted. Common failure mode was the candy cane shaft and then the wheel would just unscrew from the shaft. The compressor wheels that did not suffer shaft failure would show melting discoloration along the tip of the wheel. On a VNT the boost spike is near instant and the VNT fins have no hope of opening fast enough. Typical dyno numbers were 180 WHP and 330ft -lbs from 1.9 liters Diesel.Does this apply to variable geometry/variable vane turbos as well? My experience is with Mercedes and we just came out with the CLA45 which has a 355hp/332tq 2.0 Turbo, 26psi max boost. Not exactly 400+ but with mods I expect people to be pushing the envelope. My coworker just picked his up so I will see first hand.
