New Steeda h pipe install
archangl
South Florida
21 Mustang GT Performance Pack
Well guys I just installed a resonator delete h pipe from Steeda. I do have a stock non active exhaust. I do notice it does have a tinny sound to it, and it has a tinny sound when going up in the rev range. I am trying to see, if that’s is normal. Then is there a way to mellow it out, without having my neighbors hate me. I don’t want to go back to stock, because then it will pretty much means wasted my time and money getting it installed.
m3incorp
Georgia/Colorado
James
What does tinny mean? Is that a high-pitched sound? Hmm, you only added the H-pipe..I can't think of a way to may it quieter than to remove it. Most axle backs would probably be louder than your stock pipes. I personally don't think the h-pipe alone makes it much louder..it is a bit deeper. Add the axle backs with that h-pipe and you will hear what loud is. If you aren't starting at 6 AM or earlier, I can't see a reason for the neighbors to hate you.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
I know what you mean by the tinny tone with the non active stock mufflers. The Ford Performance by Borla Touring axle back should give you a better tone without much, if any, of a volume increase. Another possibility is adding a pair of bullet resonators to kill some of the rasp.
Excelerater
Memphis TN
2015 GT
Seems like a lot of work for no gain and pissing away 300 bucks..
Should have bought a catback
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
I just installed the Borla Switchfire, which to me looks like an H and X had a baby. Its def louder, but not bad, and it made it deeper which is what I hoped for. The stock exhaust just wasn't enough after having a 2019 with a cat-back Borla S type (basically a straight exhaust). Going to add the Roush axle back next and be done with it.
Bikeman315
Myrtle Beach, SC
Ira
Double check your installation for possible leaks. H pipes should not sound “tinny”. Also do not confuse tone vs. volume. As James said it really should be that much louder. Lastly, unfortunately many mods can be hit or miss. You can sell the H pipe, recoup some of the cost and get an axle back or better yet, a cat back. Good luck!
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Sorry buddy but that's what an X or H on a non-active exhaust sounds like. Drove me crazy on my 2018, thought for sure there was a loose heat shield somewhere or something.
archangl
South Florida
Ok thanks I was checking to see if was normal, and just saw a video of it. It sounds exactly like this: Example of H Pipe sound
m3incorp
Georgia/Colorado
James
JKL1031
Jxn, Ms
15 GT PP Premium
it sounds completely normal. I mean you can be like me and chug around the neighboorhood in 3rd, but even if you remove it and drive the same way you do now, they will still complain as an H pipe is not much louder than stock.
jd_cobra
Josh
2022 Mustang GT Dark Matter Gray
On my 2021 Gt with non active exhaust I wound up keeping the resonator and adding the Steeda axle back and it sounded really good.
m3incorp
Georgia/Colorado
James
Now that I can't answer. There are quite a few people with exhaust opinions on here.
What’s a decent sounding axle back that’s not too loud, and will deepen the tone?
m3incorp
Georgia/Colorado
James
