New Recall for ECU Safety Issues
Bullitt0819
Modesto, CA
Bob
2019 Bullitt Mustang
https://www.nhtsa.gov/recalls?nhtsaId=22V382000
Since it's 5.0 and manual gearboxes most, if not all, Bullitts are affected. I had these symptoms--reported here a couple years ago--but the dealer "couldn't replicate."
EDIT: I mis-wrote, it'a a PCM, not ECU issue (but I wouldn't be surprised if there's a connection). I hope Ford has really solved the underlying condition--my symptoms occurred when my Bullitt had sat in the sun--and not just applied a band-aid.
Schwerin
Home
2019 Mustang
I had this for a bit actually so I took it in, but since its been in, and dealer found 0 wrong and couldn't replicate, I've not had the issue since.
In my case it would happen while I was driving. Even if I had been driving at night for an hour or more all the systems would just disable. Even Rev matching. It felt like the car just went back in in time to 2003 with its lack of modern features.
Bullitt0819
Bullitt0819
Modesto, CA
Bob
Have you left your car out in a hot sun for several hours? That's when I got this problem, probably 80% of the time.
Schwerin
Home
2019 Mustang
It's only ever been outside. I don't have a garage to put it in.
Bullitt0819
Bullitt0819
Modesto, CA
Bob
I just read the notice more carefully and saw that the the issues may only happen with rev matching ON (hence the association with manual gearboxes). I've used rev matching since I bought the car--heel-and-toe isn't particularly convenient--but didn't think to disable it to see if caused the problem.
KingKona
Virginia
Shlomo
2019 GT
OP, do you realize that your link doesn't provide any info about what you're talking about, right?
NGOT8R
Adrian
2019 Bullitt
Will this recall affect tuned cars, as in wipe out the aftermarket tune?
ArtieTheOneManParty
Massachusetts
Paul
2019 Mustang GT Premium
I had this happen to me only one time. Started with backup camera showing an error, then I realized rev-match was disabled. I shut the car off, restarted, and toggled the rev match settings, and everything was fine again. I guess we'll see if I get the update, since I can't reproduce the issue.
NGOT8R
Adrian
2019 Bullitt
I’ve had my entire screen go black a few times when backing up and I had to rely on the backup sensors .
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
One time my AC in my truck wouldn't kick on. 40K miles after that and no issues.
Software has error states built into it. Its possible that some weird combination of things creates some edgecase where sure this might happen but turning it off and on again fixes it.
Bullitt0819
Bullitt0819
Modesto, CA
Bob
James1980
Poway, Ca
Jim
2020 Mustang GT
We've been discussing it here
A little more info but it seems they haven't told us all that much yet.
Bullitt0819
Bullitt0819
Modesto, CA
Bob
Found this buried in the doc:
"In some unique driving scenarios or vehicle conditions , including clutch slip
causing incorrect ratio, extended reverse driving due to miscalibration of odd/
even shift gates, and customer modifications [emphasis mine], a mismatch between the gear position sensor signal and the estimated gear calculation might be detected by the PCM resulting in a degraded signal state."
I suspect, but can't prove, the entire PCM software will be overwritten. Since manufacturers will often use 'modifications' to void warranties I doubt Ford will be sympathetic to your tune getting wiped; is a 're-tune' possible?
Side note: WTH is 'extended reverse driving?'
NGOT8R
Adrian
2019 Bullitt
Clutch slip and incorrect gear ratios sounds scary. Not sure about the extended reverse driving either.
