My procharger setup
whatsup62
Jupiter
I cant believe you guys are running that much boost 17 - 20psi and not lifting heads or gaskets. Im assuming studded heads and built motors?
ahl395
Allan
+1. Also curious if sleeved or not. At what boost level are stock sleeves in danger?
Toy Cobra
2018 GT
I have rods/pistons, ARP studs, and Cometic head gaskets. Stock block non-sleeved.
I was running a 4.38 pulley at 16-17 lbs before I upgraded the engine.
r1lovin
colorado
2015 Gt
Get the p1x over the p1 or d1
sloride
ohio
2016 GT
Can everyone give examples of timing you guys are commanding on 93 vs E85 and boost. Trying to dial in my P1X 93/Boostane around 99 octane. Thanks!
whatsup62
Jupiter
Been so long since I ran 93 kinda forget. But Im thinking Max total was 17-18 range. On E Max is 22-23
sloride
ohio
2016 GT
Yeah that’s what I’ve seen as well but trying to figure what boost level that applies to?
Roush05
Savannah, GA
2021 Mustang GT
i'm at probably 12-13 lbs with 93/boostane to 101/102 octane and i want to say i'm at 19 degrees
ProChargerTECH
Boostville
2015 Mustang(s)
I have a D1x and put down 1058 to the wheels.
Yesssssssssssss
As long as they don't detonate, they live. :)
I normally set everything limited to 23 (can't go over that)
However, if you wanna poop your pants, I have a car that runs 27...
(oddly enough, its still together lol) How in the world I don't know. LOL.
sloride
ohio
2016 GT
What lambda is being commanded with you boosted E85 guys. Currently I’m at .77 on 93/Boostane thanks
sloride
ohio
2016 GT
Yesssssssssssss
Would that be capping MBT at 23?
whatsup62
Jupiter
Well I'm no tuner but pretty sure Lambda should always trying to be 1.0. Mines flutters .97 -1.02 but is trying to maintain that 1.0. Should be that way for any fuel you run. The AFR will change with different fuel types.
.77 seems really rich.
Roush05
Savannah, GA
2021 Mustang GT
.77 at wot is fine from what I've seen. 1.0 at wot means you have a dead engine lol.. lambda is a ratio, for gas 1.00 is equal to atmospheric pressure I think In psi (14.7). A .77 lambda is equal to 14.7*.77 which is an AFR of 11.3.
It has to do with stoichiometry which I used to know about but have forgotten since I've been out of school.
