Robert3487
- Feb 13, 2020
- Modesto, CA
- Robert
- 2017 Mustang GT
I think I may have damaged this car and i'm not sure how it started. My mustang isn't my daily driver, I did the oil change with royal purple (oil and filter) and It was not leaking anywhere in the driveway. After taking the car out for a drive on Friday I got on the car up until about 3rd gear and started braking, then when I come to a stop the car stumbles and dies. I try to start it and it fires back up, but it seems like its stuttering and it dies again. I start it again and keep the rpms up to prevent the car from dying and make it back 3 block to the house. The car at this point has no lights, no check engine light, nothing. I go into the nGauge and check for codes and it comes up with the P0024 code. I start researching and found some info on Cam Phasers, low oil conditions, etc... So I start with the oil, I warm up the car for a few minutes, let it sit for a minute then pulled the dipstick. It had oil on it so I wiped it off and put it back in. I pulled it out and its dry, I figured I must not have stuck it in all the way so I put it back in and again it comes up dry. I head to the auto parts store and grab another 5 gallon container of royal purple and start filling the car which looks like it was about 4-5 quarts low. How is this possible without receiving a warning light? Low oil? I feel like something should have gone off. Ultimately I know its my fault for not checking it but I really didn't think it was loosing oil at all since its a fairly new car.
Now that the car has enough oil I started it back up and let it run for a few minutes, then I took it around the block. The car doesn't feel right, It feels like the power is there but its not as smooth. I also noticed there is a rattle when I accelerate, not a tick definitely a rattle. When I came back and put the clutch in to start braking the car died again. I start it up and its idling rough again, the p0024 code has not come back (maybe it takes time?) but the idle after the car is warmed up is about 450-500. I'm taking in to my mechanic not the dealership so he can take a look at it. From the sound of it I'm guessing he will have to be tearing the engine apart to replace parts right? I'm thinking I might as well upgrade the cams now if that's the case.
Once the car gets fixed I still need to address how the oil got that low in the first place.
