Modifying As-Built Data Guide
GatorHunter
Rob
2016 Ford Mustang GT Premium, Magnetic
Hey, new here,
Was looking at the spreadsheet and saw the soft climate buttons
07D0-01-01 xxxx xxxx x0xx for the touchscreen disabled
in my car its 07D0-01-01 6A2A 0503 20
i check a couple over VINs from the internet and found one that is 07D0-01-01 6A2A 0502 20
Im not with my car at the moment and wont be with it til June next year since im working overseas, but i believe i have the buttons on my touchscreen, would the 0503 be to enable the touchscreen and 0502 to disable?
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Has anyone seen anything relating to speed/MPH for convertible top operation? I'd love to be able to operate the mechanism at 5-8MPH vs. none, it's super handy when you're rolling up to a redliight to be able to start it moving.
In my S2K, there was two safety mechanisms, 1) speed and 2) e-brake set, and 1 was easily bypassed with a little wiring change, so then you could just engage the brake up a couple of ticks and raise/lower.
Verts get a DIC message, so I thought the logic might be available module config/BCM data.
zackmd1
Zack
[MENTION=8977]fionic[/MENTION]
Suggestion for a change to the spreadsheet... The MyColor enabling values appear to be incorrect for the Mustang. The As Built data line should read like this according to a premium As Built... I have not tested the enabling values yet but I will be tonight and reporting back.
7B7-01-1 as 0042 0000 02
There is a missing 4 digit in the spreadsheet which causes the write to fail. Likewise the disabling value should read like this according to my car's As Built.
7B7-01-1 as 0000 0000 C0
I am going to attempt to program this tonight...
7B7-01-1 as 0040 0000 00
This was pulled form the 50th LE forum. The 50th LE's do not have lighted sill plates so this code should be closer to what a base owner would need (assuming no other hardware is required) to activate MyColor in the gauges.
fionic
spaghettios and cheerios
IL
15 GT PP
Hey, new here,
your car: xxxx xxxx x0xx according to what you posted. are you saying that your touchscreen climate buttons are not disabled?
the '0503' is not the part you change. you would change that 0 to a 2 to get soft buttons for seat heating/cooling.
what's your VIN?
fionic
IL
15 GT PP
to be fair, I was told it was confirmed working :)
once confirmed by you I will update the sheet
GatorHunter
Rob
what's your VIN?
I bought my car back in march, and left like 4 days later, with what i can remember, i have the controls on my touchscreen, ill have to call my wife tomorrow to confirm it, ill pm you my vin
Edit: ok called and it does not, so do you know the difference between the 0503 and 0502?
zackmd1
Zack
Well technically it does work! Provided you have an LE with the 4 digit already in place. :p
Will report back with my results in the next few hrs.
zackmd1
Zack
So that's a no go on any of the lines... It looks as though Ford locked out this functionality from the base model BCMB or lighting control module.... So MyColor on a base model will require at least a new lighting module which is $75 from Ford.
2qwk4ya
2017 gt, 401a, auto
Just a curiosity question - when police dark mode is enabled are the mirror pony lights disabled too?
Yes there disabled
GatorHunter
Rob
Exactly, who's to say our GT's aren't doing this to some small extent as well?
They are, my 2016 had a sound tube going into the cab which i removed.
Spart
Midwest
17 GT350
I know about that and I've removed mine also, I'm referring to the electronic enhancement (or noise cancellation) through the speakers.
fionic
IL
15 GT PP
the 0502 and 0503 part, no idea. I'd leave it alone, or try changing it and see what happens.
Is there a way in the As Built to prevent the car from changing the user chosen My Color over to white during daylight? I've read threads on here where users say the center sensor on the top of the dash is what causes the color event changes depending on dusk/daylight/dark.
Can the As Built be modified so that the My Color illumination remains the same color regardless if it's light or dark outside?
fionic
IL
15 GT PP
interesting thought. we don't have anything yet, but it may be possible.
HoosierDaddy
Randy
Or if the engine is running or not. They change to white even at night before or after the engine is running.
