Modifying As-Built Data Guide
fionic
spaghettios and cheerios
IL
15 GT PP
Two more to add to the sheet:
Disable Door Ajar Chimes
IPC 720-01-02 xx0x xxxx
Rear Axle Ratio
BCM 726-12-01 xxXX xxxx xxxx
where XX =
3B : 3.15
4B : 3.31
63 : 3.55
75 : 3.73
9A : 4.10
that axle ratio was able to be written?
good find on the disable door ajar chime! weird that it's in the ipc.
Spart
Midwest
17 GT350
Rear Axle Ratio
where XX =
3B : 3.15
4B : 3.31
63 : 3.55
75 : 3.73
9A : 4.10
Interesting that the hex values are increasing even if it doesn't seem at first to be linear with the diff ratio. Have you tried plugging in other values to see if you can do in between sizes? That would be particularly useful for people who run a different size tire from factory.
fionic
IL
15 GT PP
it's literally ratio in hex, so it could work.
3.85 = x81
5.00 = xF4
etc
edit: looks like it is the first half word.
nnnn xxxx xx
where
nnnn = ratio in hex
so
3.15 = 013B
3.31 = 014B
3.55 = 0163
3.73 = 0175
4.10 = 019A
8.99 = 0383 (if it accepts it)
etc.
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
Most do it with a tune. You don't have to, but your odo and mileage will become slightly incorrect if you don't cater for the ratio change.
Cant do it with a tune, afaik. You have to do it with a whipple flare wheel/axle tool, which basically does the same thing you listed.
You should be able to change the tire size as well. I know with the whipple tool, you change it by changing the revs per mile. Don't know how easily that'll translate.
Redraven571
South East PA
Joe
2015 Mustang V6 Convertible Triple Yellow
This thread talks about the Pedal Commander and how, for $300, it can alter throttle response to make the car more responsive.
Think it can be done via Forscan?
fionic
IL
15 GT PP
perhaps maybe if we can figure out where it is maybe maybe
Freman
Australia
Eco boost 21-10-16
3.15 = 013B
3.31 = 014B
3.55 = 0163
3.73 = 0175
4.10 = 019A
Anyone know if the ratios are from a pre-set list so-to-speak. Or could you program it to any number you like. If it takes any number then would it not be feasible to fine tune this to make the speedo much more accurate?
Spart
Midwest
17 GT350
Curious about this too.
I am highly annoyed by factory speedos that purposely read fast. BMW is a huge offender here - I've observed 4% off even though the odometer was dead nuts on.
That said, my 17 GT W/PP is dead on from the factory with the Pirellis. If I decide to change tire sizes down the road, though, it would be nice to know that I can program the car to match - even it it's just 1% off.
Spart
Midwest
17 GT350
try it out
Weather's been shitty and the car's been in the garage. Finally got it out this afternoon after I installed a Steeda clutch spring but more rain just came through. :mad:
My weekend is shot, if there's good weather next week I can probably try it out though. I'd want to compare my speedo against GPS to see if the settings actually make the correct difference.
I have not seen this one asked yet:
Can the speed limiter be adjusted?
