Modifying As-Built Data Guide
Aubrey
GT4949
Sydney, Australia
Planning the next one!
I've done it twice now, I think that when I cleared a error code it resulted in the brake lights (lower 2, not roof light) to lose power. I had the dealer do a reset and they worked again, and then I did it again....not 100% sure what is causing this within ForScan, or whether I can self fix this, or go grovelling back to the dealer....
Also I managed to reset my TPMS and looks like I'll have to do a manual reprogramming unless there's a smarter way?
Thanks for any pointers, I'm on a steep learning curve coming off a low base....cheers.
77Highboy77
WA
Brad
2018 Ecoboost Mustang
Clearing error codes shouldn't cause issues with lights, unless possibly the error code is about the lighting system. Do you have a copy of you as built data for your car? If so you can go through and see where the difference is and correct it, that should fix the issue. If you don't have a copy, you can get one from the Ford site using your VIN.
Aubrey
GT4949
Sydney, Australia
Thanks for the pointer, I downloaded my as built data file based on my VIN. I then uploaded it overwriting the Forscan profile, but the power problem remained, so there’s something else going on. I’m not sure how to compare the two files.
77Highboy77
WA
Brad
Hmm, unfortunately I've had little experience in troubleshooting issues on these cars, so I'm not sure what the next step would be. I would guess some sort of short in the system that is triggering something in the system to shut the lights down, though I really have no idea.
300mag
Atlanta
17 Ecoboost Prem Vert
I'm no expert but I would check for codes in forscan. forscan pulls all the Ford specific codes.
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
I have a question Do I need my as built data guide to make changes in forscan I know what numbers to change & on what line . And I knows the stock numbers I will be changing my differential from 315... to 355
300mag
Atlanta
no, forscan displays the as built data and and you change it line that you want. it's always a good idea to download the as built data file from forscan before you make changes(you do every module individually) or at minimum download a copy of your as built data from Ford website in case you need later on.
jake_zx2
Kona Blue 2018 GT
What about OBDII->HDMI? I ask because I already have one from my SCT X4, so if I could save myself the $20, that'd be nice
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
Grimmer
Utah
2016 GT/CS M6
No windows laptop with Bluetooth... Would have to buy another piece of hardware to add it.
Has anyone figured out how to access or change any of the 6R80 or 10R80 auto trans logic via Forscan? Possible, not possible?
Grimmer
Utah
2016 GT/CS M6
Is it possible to set a drive mode other than "normal" to be the default mode?
