Modifying As-Built Data Guide
Has anyone found a way to convert the digital oil temp gauge from a "dummy" needle gauge to one that will show actual temps (like the trans temp, inlet air temp and head temp)?
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
You know how you changed 0001 to 0100... try just 0000. The fog with high beam thing was similar when I discovered it. EU was 0100 but I went with 0000.
Mine is: BCM 726-28-02 0000 0000 0057
Will try it out and report back
The lights dim when you turn the lights on though
Yes but that shouldnt happen when you step on the brakes.
msweet
Sydney
2019 Ruby GT PP 10A w/ Magride, Recaros
AngelDeath
AngelDeath
CH, New Jersey
This is the correct setting for the Fogs On / Turn Signals working. Make changes to the Data Sheet [MENTION=8977]fionic[/MENTION]
Thanks [MENTION=25893]DanMc85[/MENTION]
AngelDeath
AngelDeath
CH, New Jersey
We (export stangs) most certainly do not get the gills :(
Cool thread, in for digital speedo if possible
I stand corrected, the gills in the EU version are not lit. So that I would presume eliminates the possibility of shutting them off other then unplugging them. Which to me doesnt matter since I am going to be making the original signal lights the DRLs it wont matter to me, cause as soon as I make the gills the signal lights they wont be on during the day :)
DanMc85
The Source
New England, USA
2014 Ford Fusion Titanium AWD 2.0L
This is the correct setting for the Fogs On / Turn Signals working. Make changes to the Data Sheet @fionic
Thanks @DanMc85
You forgot your 01 at the end... whatever that change does on your Mustang.
0000 0000 0158 is probably what you should have.
dbranger94
Indiana
Daniel
Magnetic 2015 GT
dbranger94
Indiana
Daniel
Magnetic 2015 GT
So, 0726-17-02 0101 0101 014B = Remote Open Enable in my AB data.
The next line in my AB data is 0726-18-01 0101 0101 014B. Why couldn't that be Remote Close Disable?
I wonder if setting it to 0726-18-01 0000 0000 0046 would enable it?
AngelDeath
AngelDeath
CH, New Jersey
Is that not what you said to try?
Yes he did :D
And I just went down to the car to double check myself.
But his correction is right, I knew what he meant, and being its 1:30am and 4 hours sleep all day, i didnt catch that and just copied and pasted, but he is correct, it should be
BCM 726-28-02 0000 0000 0158
Fionic duly make the change in the data sheet please.
AngelDeath
AngelDeath
CH, New Jersey
Okay either I screwed something up, or I have been an idiot for the last 2 months (or i'm both), Doesnt our GT Premiums lock automatically once you get out of the car?!?
Cause I just check the fog/signal code, and when I went downstairs to the garage for the first time I forgot the key in my office, but the driver door opened, but obviously couldnt start the car. Doesnt it autolock after you shut the car off and get out and close the door? If it doesnt, then for the last two months my doors been unlocked everywhere I've gone, LOL. If it is suppose to lock, then I messed something up which could be possible but I've been extremely careful.
Car has to go to the dealer tomorrow for them to fix the passenger side back panel, think I'll ask them and confuse them :D
dbranger94
Indiana
Daniel
Magnetic 2015 GT
No, they don't. There is an Autolock feature though. See pages 56-58 in the owners manual.
dbranger94
Indiana
Daniel
Magnetic 2015 GT
Autolock Feature
The autolock feature locks all the doors
when:
• All doors are closed.
• The ignition is on.
• You shift into any gear putting your
vehicle in motion.
• And your vehicle attains a speed
greater than 12.4 mph (20 km/h).
The autolock feature repeats when:
• You open, and then close, any door
while the ignition is on and your vehicle
speed is 9.3 mph (15 km/h).
• And your vehicle then attains a speed
AngelDeath
AngelDeath
CH, New Jersey
Thanks bud, I know about it locking when the car is started remotely and when the car is in motion, for whatever reason I thought the car locks itself after parking the car and getting out. (My 2012 Vette locks itself after 20 seconds after you get out and close the door). Thank God I live in a nice neighborhood, for the last 2 months I havent been locking the door :D I'm an idiot.
Redraven571
South East PA
Joe
2015 Mustang V6 Convertible Triple Yellow
Oops! Me too, I thought it auto locked after walking away.... :shrug:
