Modifying As-Built Data Guide
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
[MENTION=25893]DanMc85[/MENTION]
720-07-01 Block write fails.
IPC
PN: GR3T-10849-EF
ST: GR3T-14C026-AE
CA; GR3T-14C088-RD
DanMc85
The Source
New England, USA
2014 Ford Fusion Titanium AWD 2.0L
Yes you can Neo :D
I left you a pm on the other forum @DanMc85 , About the gills and it lighting up.
And I pulled a vin of a GT350, to compare. Heading down to try it now. And I'll see if I can find that info you asked.
I'll take a look at it after I get back home... that fog change works on the fusion also if someone wanted that as a feature haha. I just had a friend with a newer fusion try it
AngelDeath
AngelDeath
CH, New Jersey
found my service cd for 2015 mustang.
looks like the same thing as gt350 thread has, unfortunately. also no details about each.
I have a feel a combo of the IPC and BCM would be able to have the configurable DRL option back in the menus.
But again, I could be wrong, but I dont think the gills fall into the drls cause in forscan its set to none, and no option to enable gills as a drl even if you have the menu on the Dashboard.
fionic
spaghettios and cheerios
IL
15 GT PP
very strange as the manual refers to DRLs as the gills, but who knows. this is all very exciting.
DanMc85
The Source
New England, USA
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
So we could have the fogs and gills always on? I think I might like that.
Edit: Great work btw - thank you!
I thought the gills were always on no matter what. When do they go off?
AngelDeath
AngelDeath
CH, New Jersey
US version doesnt, but looking at a couple of EU review versions, it looks like they are off (Look at the you tube video I post a page or two back), unless they are dim, and the angle makes it look like its off.
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
The EU versions don't even have the LEDs installed. There are a couple of guys over there doing retrofits and adding them in.
AngelDeath
AngelDeath
CH, New Jersey
Guys & [MENTION=25893]DanMc85[/MENTION]
I found a glitch in the setting for the fog light not to be off when signaling, I think there is more then one location for this, here's what happens at the moment:
Currently the fog lights stay on when signaling, thats the plus, but
If the car is off and you step on the brake the gills and turn signals light up.
When the car is running step on the brake the gills dim, and the night amber markers next to the signal lights act as brake lights.
When headlights are on, the night amber markers next to the turn signal remain off, press the brake and they light up, as well the gills dim.
Dont know about anyone else, but I dont like that. I am going to look at the block I was messing with and see if maybe some of the other settings countered whats happening now.
AngelDeath
AngelDeath
CH, New Jersey
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
I beg to differ, if you look at the video I posted it shows otherwise.
http://www.mustang6g.com/forums/showpost.php?p=1446475&postcount=175
Skip to marker 11:30, thats new at the dealership.
Watch as he walks to the side and the glare goes away, they are clearly off. I have the EU spec lights in my car that were retrofitted with DD RGBWA tri-bars, my oem US ones are in a closet. There are details in this thread about retrofitting the EU/UK spec lights. When they opened them, there is no LED there, just the stepped bracket that they would normally be mounted on.
GrabberBlue
Phoenix
Alex
2017 Grabber Blue GT350
A few modifications I hope are found...
Enable GT350 Digital Gauges on GTPP (Digital Speedo, Trans Temp, Diff Temp...)
Enable Sport Mode activates active exhaust valve (Allows GTPP to use GT350 active exhaust)
Enable driver seat exit movement for cars without seat memory feature
Enable Track Key (Someone just needs to try it already!)
Enable fuel dump during off throttle in sport mode (Focus RS)
I will definitely be using...
Fogs on during turn signals
Fogs on during High beams
Double honk off during no key exit
DanMc85
The Source
New England, USA
Guys & @DanMc85
You know how you changed 0001 to 0100... try just 0000. The fog with high beam thing was similar when I discovered it. EU was 0100 but I went with 0000.
Mine is: BCM 726-28-02 0000 0000 0057
TheDivaDanielle
Living the Dream
Washington DC
Danielle
2016 GTPP Vert / 2016 Focus RS
