Modifying As-Built Data Guide
z06psi
Evans, GA.
Andrew
The pot stirrer
O.k. I have one I need some help with.
When in Andoid Auto I am not getting the HVAC temp display when you change the temperature. Anyone have an idea which line to change?
TIA
prj_tchalla
Georgia
2016 Mustang 2.3L Ecoboost Convertible
not available at all on the S550... just global down.. not up
It IS AVAILABLE on the S550 convertible. I have it on my 2017 Premium 401A package convertible GT.
BUT it IS NOT on my 2016 Premium 201A package convertible Ecoboost.
It was added in 2017
Spart
Midwest
17 GT350
TIA
This is in your car that you did a swap in, right?
z06psi
Evans, GA.
Andrew
The pot stirrer
Well not exactly. :lol:
Bought a 2017 Navigator.
When in Android Auto the volume shows up when you adjust. The temp doesn't.
The Mustang works just fine. :D
Spart
Midwest
17 GT350
Huh. Interesting.
Have you looked at the F150 spreadsheet? There's some pretty detailed documentation of the APIM in there, and IIRC there's a section that deals with the display of the volume.
Aurum
Los Angeles
I'm probably misreading - or missreading - the spreadsheet, but it isn't clear how to switch the sync 3 theme from the default pony to the ford GT.
Is this the correct setting?
Sync/MFT Startup Animation (Mustang Pony, GT) Enabled APIM 07D0-02-01 xxxx x6xx xxxx
None of the values are clearly labeled Ford GT.
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
7D0-02-01 xxxx xDxx xxxx GT Ford Performance BOOT screen
7D0-03-01 xxxx x4xx xxxx GT Ford Performance SHUTDOWN screen
AngelDeath
AngelDeath
CH, New Jersey
I Thought I had the code for the fog lights to come on with the parking lights when you manually turn the dial, but it seems the codes for the parking lights and fog lights to come on as DRL's which I dont want. Anyone found that code? The reason is at times when I drive its dusk where headlights really arent needed but putting on the parking lights and fog lights suffices.
Thanks.
Scott Wilson
s550 is life
Central TX
Anyone know how to change tha As built to get the 2018 digital speedo found on the base models for 2018? That would be cool to have on my 16 but I'm not sure if it's a software thing that needs to be changed
breeves002
Gold Sponsor
St. Louis, MO
Sam
2016 GT Premium PP
This question has been beaten like a dead horse... You can get a 2018 base/premium/digital cluster to replace your current one. Only way.
Spart
Midwest
17 GT350
Or you flash your 2015-17 cluster with GT350 firmware and deal with the problems that brings.
