TexasRebel
Gearshifter
- Mar 19, 2016
- between the mustard and the mayo
- 2016 YZ GTPP - PP2
As Ford makes a 4.09:1 ring & pinion set for the super 8.8 which doesn't come in any car, logically the diff ratio should be configurable.
Have you figured out what to change in both the PCM & BCM?
FRPP has this to say about ring & pinion changes
As I was saying earlier, the Power Packs come with a ProCal device which allows easy gear ratio changes. I don't know if ForSCAN can touch all of the necessary memory.Requires aftermarket calibration if vehicle is not originally equipped with this gear ratio or a Ford Performance Power Pack Calibration
