Mobility kit vs. Spare tire
Brazos609
2015 GT Premium PP Recaro
From the picture, the spare is a 165/70-18. The circumference is 27.1" by definition. If you go with a 275/40-19 square setup, you'll be at 27.7" all the way around, a 2.2% split across the differential with the spare.
I just measured the brand new, zero miles Explorer spare and brand new, zero miles MPS4S 275/40-19. The spare has a circumference of 86" and diameter of 27 3/8" and the 275/40-19 has a circumference of 86 3/4" and diameter of 27 5/8". That is a difference of only 1/4" in diameter or 3/4" in circumference, either way, less than 1% difference. I'll add a 1 1/2" hub centric spacer to the trunk and the spare should now clear the 6-piston front calipers. This is solely for emergency use only.
69mach1-395
central nm, usa
2016 RR GT/CS
Thanks for the measurements. Why 1-1/2" spacer vs. 1"?
Brazos609
To clear that big ass caliper. I forgot that I actually had a generic 5x4.5" 1.5" spacer from a trailer project and I used it to check today and 1.5" isn't even enough. The steel 18" Explorer spare and aluminum 18" Mustang spare both rub the 6-piston caliper with the 1.5" spacer. I went ahead and ordered a pair of 2" hub centric Mustang spacers today. This is just for emergency use to get me to a safer place to be picked up by the tow truck or home if close.
69mach1-395
central nm, usa
2016 RR GT/CS
Now I'm wondering if a 1 incher will allow it to clear the standard Gt front brakes...
Bullitt0819
Modesto, CA
Bob
2019 Bullitt Mustang
Has anybody fitted up the Automotive Authority wheel to confirm it fits (clears the calipers)?
Brazos609
They do it on video, it's up on their site. I would like to see someone measure the actual circumference of the AA 19" spare to see what it is.
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2018 Jeep Grand Cherokee Summit
BrettT
Richmond, BC
Brett
2019 Bullitt, 2006 Jetta 2.0T, 2013 Escape SEL
Ordered the AA spare tire. Just got the spare not the whole kit. Also ordered the Ford Mustang Jack and accessories.
rebellovw
Prescott AZ
2018 Mustang GT Premium PP
I’m glad I bought the AA spare tire kit. I feel much better having it vs the mobility kit.
Wait for a tow truck?? Hell no.
BrettT
Richmond, BC
Brett
Got my AA spare and Ford Mustang jack, lug wrench, retainer and plate. Going to put them in the trunk today. What I seem to still need is a handle to operate the jack. Does the lug wrench also act as a jack handle for operating the jack?
rebellovw
Prescott AZ
Yes.
frankeric16
cary, nc
frank
2019 DHG Bullitt
Ford FMCF0004 Mechanical Scissor Jack (1.5)
by Ford
and
T1A Scissor Jack Adapter for 1/2 Inch Impact Wrench or 13/16 Inch Lug Wrench Adaptor, Used for Automotive
both via Amazon
Zooks527
Yes. The operating nut for the jack is the same size as the socket on the end of the wrench.
For my car, I also keep an 18" breaker bar with a deep 6-face impact socket for the lug nets. Gives me that much more leverage if needed when the time comes. Also keeps the socket where I know it is when it's time for for winter tire swaps in the fall and spring. It aso lets me know if the covers on the nuts have started to swell to the point where the socket no longer fits (damn Ford two-piece nuts), I can then upsize the socket so that I always have the right size in the car.
EDIT: Actually, it's an 18" breaker bar, not a 12". It fits nicely under the bottom edge of the spare across the width of the base of the well.
rebellovw
Prescott AZ
For my car, I also keep a 12" breaker bar with a deep 6-face impact socket for the lug nets. Gives me that much more leverage if needed when the time comes. Also keeps the socket where I know it is when it's time for for winter tire swaps in the fall and spring. It aso lets me know if the covers on the nuts have started to swell to the point where the socket no longer fits (damn Ford two-piece nuts), I can then upsize the socket so that I always have the right size in the car.
I’m thinking about doing that as well. 150ft lbs is pretty tough to deal with.
