Mis-fire Cylinder #2...now #2 and #3
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
You do understand the porcelain dosent just drop on its own free will.
I'm sure it had a perfectly legitimate reason to fail. If it was just to piss me off, it worked.
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
Seriously, I'd love to hear some WAG's on why it went boom. (Wild a$$ guesses)
perfweld
Northern CA
2015 Ecoboost Mustang
They must not be a very good plug if they just separate like that for no reason, my guess would be detonation. Id change brands anyways, not something id want to deal with.
5.0yote
AKA Bananana & 3.7Cyclone
Mansfield, MA
www.youtube.com
Don
2016 Mustang Ecoboost Premium
Bad plug...very bad plug
That looks like an overheating issue either a pre-detonation or lean condition followed by the plug's insulator cracking under heat.
With two misfire situations I would not put my money on faulty plug.
dgc333
MA
15 Mustang Ecoboost Premium
Could be a lot of things, but the very most likely cause would be detonation.
Don't know if you can say detonation is the most likely cause. The plug could have had a hair line crack when it was install from being dropped or gapped that propagated over time until it failed.
If there was detonation you should be able to see fine bits of aluminum on the insulator.
Spoolin
San Antonio, TX
Mustang Ecoboost PP 6spd Manual
I had this same problem and its was none of the problems stated above. It ended up being the caps that screw into the top of the plug had a little play in them causing a lot of misfires. I was trying everything to fix the problem and Adam recomended that I check the tips to see if they were loose. It seemed normal because they had play but weren't like falling off. I tightened all 4 and all missing went away.
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
Driving today...new plugs and another CEL. P0303 again. Definitely will tighten up those caps and connectors.
Spoolin
San Antonio, TX
I'm about 100% sure that's it cause I replaced the ones I was getting codes for misfiring and the problem came back in like 20 miles. A big headache, I don't think I'll be purchasing densos again lol
doulos4jc
doulos4jc
......looking^
2015 Turbo Mustang
Just checked old densos, two had loose caps including the one that failed.
TEXAS HEAT
TEXAS
2019 Mustang GT PP1 A10
It seems like I've heard that some users of Denso's having issues with the electrodes breaking off. I've personally only ran them once in my Mazdaspeed before switching to NGK then Autolite Iridiums which I learned are the same plug. Having said that, I did purchase a set of Denso's from Adam, but I haven't installed them yet.
Slow89
Some place out west
11 sec bolt on ecoboost // 9.2 @ 151 2019 blower GTCS
almost ALL vendors and other big mustang names on here won't touch Densos for what it's worth.
