Cylinder 3 Misfire AGAIN!!
evan546
2015 Mustang Ecoboost
My car is now has a rough idle and sounds cammed.... It runs fine for a couple seconds and then goes into weird mode im thing its a bad spark plug hopefully or it is a gapping problem i need help please!
turtleboy
Palm Springs, CA
15 EB
check the gap on the plugs. Also might have gotten bad gas, you always fill up with premium at a reliable station?
Dramad1
San Diego
2015 GT, PP, Blk
Could be a bad coil pack as well. I haven't had that issue on the Mustang platform yet but I've had issues with my last ride and coil packs
evan546
Im thinking its an overheating plug because its an on and off occurrence typically when the car is hot or being used i have a tune so in thinking i shouldve bought the colder plugs
Sent from my SM-G900P using Tapatalk
wmsky33
Georgetown, TX
Bill
2015 EB PP 6MT Competition Orange
Hey evan, it's me again; guy with bad plug from other thread. I'll tell you this; last thing I did just to verify that the plug was bad was, after driving 2 days with the factory plugs back in and on the stock tune and the engine running perfectly, I put just the plug I had determined was bad back into the engine. Started the engine and it was idling smooth. My first thought was "Did I get this wrong? Is the plug OK?" Then the engine warmed up and started running like crap, and the idle was crap too. I figure that when the plug warms up, the heat causes something in the plug to crap out.
If you want to do a pretty cheap test, just buy one replacement plug that's one step colder than stock, and replace just the #3 plug. If the problem goes away, buy the other 3 plugs. Having the one plug that's a slightly different heat range than the others will do absolutely no harm to the engine. Just make sure to gap any new plug you put in to 0.026. Adam of MAPerformance has determined that that is the gap that is optimal for most EBM engines.
evan546
You are the best om going to do that before i go to the dealer
wmsky33
Georgetown, TX
Bill
Can i use this plug?
Don't see a plug in your post, however NGK 6510 and Denso ITV22 are both one step colder than stock and both should be carried by just about any auto store.
MAPerformance
Cottage Grove, MN
www.maperformance.com
Sales
2015 Ecoboost Base w/ Performance Package
Why didn't you just post this in the thread you already created. Anything we can all do to keep this forum from being cluttered is greatly appreciated! I feel like we gave you a lot of resolutions in the other thread.
Are you on stock intercooler?
evan546
My apologies I ended up taking the car back to the dealership because i had to do service anyways they're saying its bad gas but it did this months before
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
Are u running 93?
evan546
Dealer just called me theyre saying that the car is working but has a few hiccups they want me to return to full on stock to do more test. Would a KAM reset resolve this issue im thinking that i got a bad tune as the car will still run its just in the higher speeds/accelerations it begins to misfire.
