All there parts are 304 stainless steel. Thats pretty standard in the exhaust industry. I dont see what alternative solution you think would be better here but this kit will be find for your application.
Thanks man I appreciate itIf its all from t304 stainless steel then you will have no problem at all. Even the aluminized steel you will have no problem. If you were somewhere there is a lot of salt on the roads the aluminized steel would rust. But your in FL so you can use either material. The stainless steel is just more expensive.
Repping FL dudes :cheers: Lethal Performance is my hometown![]()
Same, live like 10mins away from lethal
