Wonder if they learned the OAR on the Cobb tunes, and purposely not on the stock tunes. I wouldn't give them that much credit though.Yeah it was a poor comparison but it was still gains of 20 hp and 100 tq so that means more power when the octane level is fully adjusted.
From my understanding the OAR happens automatically and it determines if you are using good or bad quality fuel.Wonder if they learned the OAR on the Cobb tunes, and purposely not on the stock tunes. I wouldn't give them that much credit though.
Other possibility is that the Cobb tunes off-the-shelf modify the OAR to be higher all the time, which is BAD news for anyone running less than perfect quality 93 Pump fuel.
Yep, but if you flash and run immediately, it may take several runs to fully learn. By default the system assumes 87 pump and learns up or down from there.From my understanding the OAR happens automatically and it determines if you are using good or bad quality fuel.
Best way to learn is gradual accels in gear, varying pedal between runs. Or just go all out and WOT runs!Sounds good. When I get my AP im going to have the OAR set as one of the gauges so I will know if I have good quality fuel.
