Manifold Swap Diagnosis Help
Jakewright600
Cincinnati
Jake
Hi all, I have a manual 2016 GT and I did a 2018 ported manifold with 47lb injectors. Got it all on and put the tune on and upon start up it seems to be working itself out like usual after a new mod and tune, but then rpm’s started climbing and climbing while in neutral until eventually I shut it off when they seemed to level off around 2500. headers were glowing red
the next day I double checked everything again, re flashed the tune and it was basically doing the same thing, but I took it around my neighborhood to see if it just needed to learn the tune. While driving and in gear it was completely fine, but when you clutch in to shift the rpm’s spike up again to like 1600-2000. Car did throw a p0507 for high idle.
I think I’m running lean based off my headers glowing red the first time, but am at a loss as to what could be causing the rpm spikes and high idle…vac leak? Bad injector? Bad sensors?
brand new here so appreciate any help or input!
thanks!
Rusty67
Los Angeles
Jeff
1967 Coupe, 2003 Mach 1, 2012 Boss LS
Sounds like you have a vacuum leak. Try getting a can of brake cleaner and spraying it in different spots around the motor. Don't go nuts and spray all at once. Spray a little bit in a specific spot and wait for the engine to change what it is doing. That can help find the leak. It is possible a gasket isn't sealing or that you have a line that is not all the way on somewhere under the hood.
P.S. don't use carb cleaner, it will damage rubber.
SheepDog
Colorado
Dax
Vacuum leak. Like Rusty67 said, spray short bursts of brake cleaner around the throttle body, intake piping, intake manifold, basically anything after the MAF sensor. A more precise way to tell if you are spraying in the correct area, is to have your tuning device or OBD2 dongle/app showing Short term fuel trims. If you are in the right spot, you will see the fuel trims change towards negative when the engine sucks in the brake cleaner.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Have you done any logs? An idle log will show a vacuum leak. Many things can cause the high idle. The glowing headers can be caused by retarded timing trying to reduce idle.
What tuning device?
Jakewright600
Cincinnati
Jake
What tuning device?
PBD tune with x4…I sent in idle logs and asked if they can tell anything from it, but haven’t heard back yet.
K4fxd
NKY
Do you remember what the short term fuel trims are? "STFT"
K4fxd
NKY
It sure looks like it is getting unmetered air.
Rusty67
Los Angeles
Jeff
Quick tip for when you are spraying to try and find the leak. You should use the straw the can comes with to keep the spray pattern nice and tight so you can be more precise as well as get it directly into the nooks and crannies under the hood without over spraying everywhere else. Helps to keep the guess work down.
Jakewright600
Cincinnati
Jake
Already replaced and tossed it, but It was one of the ones that we repurposed from the brake booster etc. line. Im assuming we knicked or hit somewhere and missed it first time around. Also we reused the gasket from the original manifold on the throttle body, switch to the new one this time, could have also played a part.
