Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2023 F150 Raptor
- Vehicle Showcase
- 2
What do you think of the Steeda subframe alignment pins ?
They fit perfectly. Luckily for me my sub frame must have been pretty center because I didn't have to wrestle it at all to get them in.
Three tips on these.
1. There are 2 different sizes in the package. The directions don't even mention this. The shorter, fatter ones are for the front bolts and the slightly taller skinnier ones are for the rear. Thought I'd save some time for you guys and put that right out there.
2. They only fit one way. The directions say this but to ease the confusion just use the first subframe bolt you take out and try and slide the spacer over it. It will only bottom out in one direction because of the counter bore in the spacer. The wrong way and it will not slide completely over the bolt. Easy as that.
3. When tightening the bolts be sure to use the jack to lift the subframe all the way back up. With it dropped even just a little the holes become off center and it will cause the bolt to bind up when going back in. Don't wanna strip these puppies.
Jaime
