Mach 1 Oil Filter Gasket, Don't Lubricate?!
ChitownStang
Chicago, North Shore
2021 Mach 1
3 oil changes so far for me in my garage. I always dip my finger in a little oil and do a slight run around the gasket.
Hand tighten as much as my forearm can do with a glove on,
Never had an issue and it is always been pretty difficult to get off by hand, usually have to use pliers.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
how many miles between changes?
ChitownStang
2021 Mach 1
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
I just did mine dry. Weird, but it tightened up just fine. I also marked the end cap with a grease marker in case it rotated. I was on the fence but if the OEM recommends it I usually do it.
swoop1156
22 Mach HP, 22 Raptor 37PP, 22 Cayenne Turbo SE
I used to do my own but with my 10y/100k warranty and minimal miles - all the risk falls on the dealer. I'm a record-keeping hound ever since I had my Focus SVT eat it's Getrag MT285 one day in 2003.
I'll leave it to them to do nearly everything aside from fuelling the damn thing. ...as I go install an MGW 🤣 Okay that's the one exception!
IanKar
Canada
Ian
22 Ford Mustang Mach1 HP A10; 22 Shelby GT500 HP
I read about this as well. Found this link on youtube where FordBossMe showed the specs on his post-not to lubricate the oil ring.
I still put a tiny smear of oil on the gasket. Just didn't have it in me to put it on dry. So far so good...
mattlqx
Driver
Mesa, AZ
Having had this filter on the early GT350s and tracking the vehicle with no problems, I have to say just tightening the crap out of it with lube and a filter cap socket (they even sent GT350 owners them as a supplement) till it doesn't move anymore worked fine for me. I'm pretty skeptical that this cross-plane crank engine vibrates anywhere close to what the flat-plane crank engines did.
DrZed
Canada
Cam
2021 Mustang GT PP1 M6
I'd want to see the TSB on this. Not lubing the gasket can cause it to tear.
There was a thread on this a while back. The service manual for the 5.0L and 5.2L engine says DO NOT oil the rubber seal. I didn't believe it until I read it myself. The harmonics of the Voodo flat plane was causing spin on filters to loosen, but not on the 5.0L, so not sure why that direction was given to the 5.0L filters.
DrZed
Canada
Cam
Random thought: does it bother anybody that Ford is one of the few OEMs that stock their oil filters without any protection covering the top of the filter? Meaning any dirt could drop into the fresh oil side of the filter if mis handled. Most other filters come sealed or with a plastic top cover. Always bothered me a bit...
jsullboy
Ontario, Canada
2021 Mustang Mach 1
I was thinking that very same thing. Seems like an unnecessary risk not having the oil filter protected before installing.
Skye
≈39N
"Skye" Mach1 N2144
Last season, I changed the oil (factory fill) and replaced the filter. Like many, I lubed the filter gasket with a touch of oil and installed hand tight (3/4 to 1 full turn, once the gasket touched the block).
I changed the oil a few weeks ago. No issues. The filter hadn't budged and I didn't expect it to.
New filter was installed as before. I've never had a filter loosen, nor have I had one become stuck or "welded" on.
DougS550
Indiana
Doug
I always lube my oil filter gasket BUT: I put a band clamp around the oil filter with .032 stainless safety wire and safety wire to prevent any movement.
Cobrajet70
clermont
Jamie
21 Mach 1 Hp
Nothing new, Ford has had that in PTS for decades.
I've seen a number of filters come back loose and found it was from tech thinking they were doing right by pulling oil on the O ring. Never seen one come off but I know the GT350s had issues with them coming off even with the Loctite that's on the filters.
Its not going to tear, this isn't 1940 anymore, hand tight after wiping down everything and use a wrench to remove.
Rapid Red
Woodstock GA
Greg
Those oil filter gymnastics you speak of are totally on the users. Sure, read some outright BS folks trying to blame the oil filter.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Why not stick to Ford recommendation? The worse that can happen is the filter gets stuck right?, but you can use a good removal tool if that happens. As much as I hate it I am thinking I will have oil changes done at the dealer at this point though. I need the documentation for whipple warranty as well.
I decided not to have the dealer change my oil. First oil change filter was left loose(most likely the tech didn't tight enough or maybe they lubed it and didn't tighten enough? who knows). So The next two oil changes I did and I put it on dry per the recommendation. No issues, plus its not completely dry there is always some residue or oil that leaks on to surface.
