Loud screeching sound on cold start up
bobdes368
New Jersey
Bob
2023 Mustang GT Premium
The temperature is dropping here in the North East and I have been hearing a screech when I start the car. If I press in the clutch pedal it stops.
Then when I release the clutch pedal it makes the noise again. The screech stops after the car get warm. Any ideas?
2023 GT with 3,900 miles.
Thanks
Hack
Minneapolis
Mustang, Challenger
Take it to the dealership right away. I was going to say throw out bearing, but that should only have an issue when the clutch pedal is depressed. If you have the transmission in neutral and the clutch pedal is released, the input shaft on the transmission is turning. The input shaft will not be powered by the engine if the clutch pedal is depressed. It could be a transmission problem related to the input shaft, I suppose. It doesn't seem likely to me, though.
Possibly the throw out bearing is somehow dragging against the clutch when it shouldn't be. Problem with the master cylinder or something. I'm not sure how any of the issues I've mentioned would have anything to do with cold temperatures, though. Unless there's water in your brake fluid (I seriously doubt it).
526 HRSE
California
2017 GT350 Grabber Blue
Obviously, the first thing i'd suspect would be a belt.
paulm1
Northeast PA
pau
2021 GT mustang
open up the hood when it's making the noise, see if you can tell if its coming from the front of the engine or the back.
Hack
Minneapolis
Mustang, Challenger
How is the clutch changing a belt? I do agree that belts and pulleys tend to squeal on startup, but he said depressing the clutch made it stop.
David Schmidt
North Carolina
David
2018 GT Premium MT82 PP1 401A
I thought exactly the same thing, just reading the title. Cold screech? It's a belt. :like: Ok, yeah, clutch changes it... that's something else. In the immortal words of Col. Rhodes (in Iron Man): "...I think you should lead with that next time." :wink:
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Hack
Minneapolis
Mustang, Challenger
Throwout bearing ... pilot bearing are the usual suspects.
But shouldn't the symptom be reversed if it's one of those? The pilot and throw out bearings should both be unloaded when the clutch pedal is released, correct?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
You would think. I had a howling pilot bearing on another Ford that went away when the clutch was depressed.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
I would check the play on the belts first
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Yep sounds clutch related (throw-out bearing). I would turn it on pop the hood and try to locate the location of the noise. Then spray some belt dressing just to double check - I doubt its the belt but doesn't hurt to check. If the sound is in the back of the engine you will know its most likely the throw-out bearing.
