LOST COMPRESSION ON ALL CYLINDERS
JPG350
North Carolina
Juan
2017 GT350
Hello gents,
I am not sure if this is the correct place to post this question, if it is not i apologize.
My 2017 recently shut off on me while driving, no bang, no knock, just shut off. I verified fuel, spark successfully. next i bought a compression gauge and conducted a compression test and my results have me scratching my head. Across both banks on all cylinders I am getting 30psi which has me very confused.I do not have oil/coolant mixing anywhere.
My question is, how is this possible? May i possibly be doing something wrong while conducting the test? Any type of recommendations or advice is greatly appreciated.
BTW my engine has about 18k miles and has following mads:
Procharger stage 2 kit, Longtubes, Cat/Res delete, RXT1200 clutch.
THANKS
Juan G.
Lilmags500
Peoples Republic of Massachusetts
Jody
22 Mach 1 19 F350 20 Fusion Ti 19 Escape Ti
Sounds like you lost your timing chains , can you verify your cams are turning when you crank the engine over ? Pull the valve covers and
have a good look ..... Sounds like your valves aren't opening / closing ....
95CobraR
Sandy Springs, GA
Doc
2019 Shelby GT350, 2025 Porsche 911 Turbo
All eight cylinders showed 30psi of compression?
Hack
Minneapolis
Mustang, Challenger
Are there instructions in the service manual that you followed when running this compression test? With a carbureted car, it's easy to access the throttle blades to hold them open and there are no electronics that might be "confused" by the open throttle during cranking. On a modern complex engine I would probably not run a test like this without a manual to follow.
JPG350
North Carolina
Juan
2017 GT350
i will pull the valve covers and take a good look at that. thanks
JPG350
North Carolina
Juan
2017 GT350
I did not follow the manual since i do not have one yet. i did watch a few videos and followed those to the t. to bypass the throttle blade issue, i actually removed the throttle body completely so there would be no restrictions thru the intake.
Lurker_350
TX
2016 GT350 - Tech
Cliff notes from manual:
  1. Make sure oil is correct viscosity and level. Make sure battery is charged. Operate vehicle until engine is to temp. Turn ignition to OFF and remove all plugs
  2. Remove air cleaner outlet pipe
  3. Disconnect throttle body electrical connector
  4. Set throttle plate to wide open
  5. Install compression gauge on No. 1 cylinder
  6. Install auxiliary starter switch in starting circuit. With ignition in OFF position, use auxiliary switch to crank engine minimum of 5 compression strokes. Record highest reading.
  7. Repeat on all cylinders.
  8. Put it back together.
Seems like removing the throttle body would accomplish steps 2 through 4.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
That sounds like user error or a malfunctioning gauge to me. Are you sure you're getting a good seal? I can't think of anything that cause compression issues across all cylinders
JAJ
Vancouver BC
2016 GT350 Track Pack
If something was doing a really good job of blocking the intake, you'd have big manifold vacuum and low compression numbers like this.
JPG350
North Carolina
Juan
2017 GT350
I am going to take a picture of what im using and hell maybe even a video of how i'm doing it and the results.
i actually watched your video sir and did it exactly like you did except i removed the throttle Body to make sure nothing would be blocking intake.
the car had been sitting for 2 weeks at a body shop and i made it about 2 miles from the place and it just shut off. no low oil lights, oil pressure alerts, banging, knocking or anything.
Tank
9/11 - Never Forget
Above the Notches
G0853
Hook it up to an OBD reader and see if you're throwing any codes.
Seems to me a compression test is a step or two down the diagnostic testing tree from the symptom you described and the mods you have.
JPG350
North Carolina
Juan
2017 GT350
P0017 CMDTCs
P0138 CMDTCS
P0339 CMDTCs
JPG350
North Carolina
Juan
2017 GT350
Now when screwing the 14mm adapter in, does it usually screw all the way down to the o-oring?
