Loose transmission tone ring nut?
Musclecar
Midwest
2016 GT350
Wondering if a loose transmission output shaft tone ring nut is causing my 2016 to drop revs when on the highway and mash the accelerator pedal. Cruising along at say 4000 rpm and mash the gas without downshifting the revs immediately go up to 5000 but then drop back down before the car finally takes off. I found TSB 19-2135 which talks about a loose tone ring nut causing hesitation without throwing any codes, but it also mentions cruise control not working. I am not having any cruise control problems and not getting any warning messages like "service drivetrain". Anybody else experience this? It seems that once it gathers its bustle it accelerates linearly and strong.
Tank
9/11 - Never Forget
Above the Notches
G0853
Sounds to me you need to get the car checked out under the TSB.
The cruise control Section of the TSB has a ‘may not work’ clause. It doesn’t say the TSB doesn’t apply if the CC is working.
Good luck :like:
madweazl
Fredericksburg, VA
'19 GT350
The only thing linking your engine to your drivetrain is the clutch. It is the only thing that will slip and cause the issue you describe (provided the engine is actually revving). In the early stages, it will begin to slip easier in the higher gears (4-6 for instance).
03reptile
2019 Shelby GT350
Agree with madweazl .Sounds like your clutch is going bad.
Musclecar
Musclecar
Midwest
2016 GT350
My initial thought was clutch or pressure plate but then I saw the TSB. I tried the 4th gear start clutch test and engine immediately died so that is inconclusive. 16,000 miles on car. Looking to see if anyone who went in for this TSB had similar symptoms. From reading through the TSB it looks like an improper signal can be sent to the computer and the throttle drops out.
madweazl
Fredericksburg, VA
'19 GT350
Your description is that in 4th gear, you can hit the gas and the engine will rev up 1000rpm with no additional force being applied to the wheels, correct? The only place that energy can go is the clutch. It sounds like some sort of torque management is being applied after that if the rpm drops again (usually it will just keep climbing once the clutch is slipping).
Musclecar
Musclecar
Midwest
2016 GT350
No its more like pulling out to pas and hitting the gas the revs go up and the car starts to takeoff but then the bottom drops out and loose revs and speed before then kicking back in and car accelerates with the revs.
madweazl
Fredericksburg, VA
'19 GT350
Ah, ok. No clue on that then.
Musclecar
Musclecar
Midwest
2016 GT350
I had that exact same problem. Hesitations with bursts of revs during freeway cruising speeds but my cruise control would still be functional. It turned out to be the output shaft but was loose. I tighten it to 105 ft/lb with thread lock and the problem was gone.
Thanks for the input and photo. The car's still under warranty so I'll take it in and mention the TSB.
11GT50
Union, WA
2017 GT350
How loose was your output shaft? Was it loose enough that you could feel it with your hands or only when you put a wrench on it?
Slidingsidewayz
Los Angeles
Fred
17 gt350
It was loose enough to spin it with a socket by hand. I was surprised to see how loose it was with only 15k miles on the odometer.
11GT50
Union, WA
2017 GT350
It turns out mine was the same way. I've been chasing a problem and thought it could be it. Turns out it wasn't but I'm glad I caught it anyway. I put mine back together with a little blue Loctite.
