Loose shift knob
eemcclain
Conroe, TX
Eric
2022 Mustang Mach 1
My shift knob has become annoyingly loose. When I try to tighten it, I can’t put it in reverse. Anyone else have this problem?
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
If there is a lock nut on it you can take the knob off, raise the nut a little bit and then tighten the knob. If there isn’t a lock nut (stock) then I would get one cause it will fix your issue. Any aftermarket shifter will come with one if you’ve had your eye on some fancy balls lately…?
LCK22GT
Michigan
Larry
2022 Mustang GT / 2021 F150
a few daps of Locktite blue when you have it set right.
VoR
San Diego
Vic
2022 Mustang GT
First post nailed it. Adjust the lock nut up if there is one, or get a nut and the knob will tighten against the nut.
No locktite needed at all.
John S
Novi, Michigan
2022 Mach 1 HP
My Mach 1 shift knob had no jam nut and the Loctite would not allow the knob to loosen. It took so much effort to remove, I don't know if the "soft" threads will ever be the same. Even though the Tremec is supposed to shift fine with the OEM shifter, I went with MGW, and for me, the upgrade is worth every penny.
